Attn: Vader, GGA, zroc etc. (Cont.)
Old Apr 14, 2002 | 09:21 AM
Vader's Avatar
(Time for a new page...)
You certainly can't beat a leakdown test for diagnosis. When seven cylinders range between 8.5% and 13% leakage on a cold engine, and the eighth leaks at 95%, it doesn't take a rocket scientist to isolate the problem.
Guess what the exhaust valve looks like on a bad cylinder, compared to a new one:
Attached Thumbnails Attn: Vader, GGA, zroc etc. (Cont.)-exvalve.jpg
Old Apr 14, 2002 | 05:54 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey Vader,
We made it back just fine!
Yeah, that valve was bad, and I've been thinking about it today - Im almost a bit surprised that the seat didn't take more of a beating from it? If it had not been for the piston that doesn't show any sign of contact - I would've thought that must have happend recently. But as you said, it would've had to hit something and it obviously wasn't the piston.....
Oh well! Im looking forward to hear what you find out at the machine shop - and most of all, Im looking forward to hear my baby purr again before too long
Ken
Old Apr 14, 2002 | 06:10 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
How does something like that happen?...so I know NOT to do it
Old Apr 15, 2002 | 10:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Sure that's not one of those canted valve heads?
Old Apr 16, 2002 | 11:25 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Was there any damage on the corresponding piston?
Old Apr 16, 2002 | 12:30 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
We couldn't see any damage at all to the piston - so the assumption is that this happend when the heads were installed on a previous engine. Our guess is of course also that this has been one of the main reasons for all the trouble that we've been chasing in the previous 4(?) threads that we've gone through regarding my car on this board over the last 3-5 months...
Currently Vader is waiting for a set of injectors and a set of roller rockers to arrive before putting the rest together.
Vader, did you get the pics of the cam spec card last night?
Ken
Old Apr 16, 2002 | 02:12 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I had the same exact problem with a set of "good" heads i bought off a "buddy". There was a bent valve on both heads one intake and one exhaust. I found the exhaust valve real quick but the intake valve took 2000 miles to start leaking. A top end tear down and one less "buddy" later and the prob was fixed.
Old Apr 16, 2002 | 07:49 PM
Vader's Avatar
Mike, As a matter of fact, I think it might be. It "CANTED" have possibly run right with that valve in the head.
Incidentally, Comp ground the cam 1/2 degree off (retarded), or my coat hanger wire isn't calibrated. I couldn't have installed the degree wheel a half-degree off, could I? Not ME!
Degreeing the cam showed it was off by 17.75°. If you do some simple math with the tooth counts on the crank and cam sprockets, if the chain set is installed one tooth off, the difference should be about 18°. Guess what I found when the timing cover came off? You can't blame the installer, since the crank gear was marked oddly. I got the auto center punch out and fixed that, too.
Attached Thumbnails Attn: Vader, GGA, zroc etc. (Cont.)-timingmarksoff.jpg
Old Apr 17, 2002 | 02:11 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
yup... that will do it... cool... glad you guys got some results...
Ken, what does the interior of a death star look like??? lots of cool stuff to play with??? give Vaders dog a pat on the head for me...
zroc
Old Apr 17, 2002 | 11:08 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Wow, I'd blame the installer (Ken) ...just because.
BTW, I have a calibrated coat hanger in the closet...if you suspect your may be going bad.
Old Apr 17, 2002 | 11:58 AM
Vader's Avatar
Mike,
I may take you up on that calibrated coat hanger, as long as you don't want too much for it. Do you have the cert that indicated NIST traceabilty, or will I have to have the calibration checked? Otherwise I'm hitting eBay and I'll get one there as long as the bidding doesn't get stupid-high.
And as for the timing, you can blame anyone you want, but the crank sprocket was marked "NO", presumably meaning "Normal" about a half-tooth from the smaller, more obscure "dot" that is supposed to be used as the alignment indicator. Too bad the photos don't show it more clearly, but if you zoom in you can see a little of it. As I stated earlier, the "dot" was actually a small circle that was barely stamped in the face of the sprocket. Aside from that, the marks on the crank sprocket didn't match the installation instruction sheet provided with the timing set. Great, huh?
I can understand the confusion, and it's another reason I'm not really hot on the "three-way" crank sprockets. Other kinds of "three-ways", well, that's a different story...
Besides, I know you were just jerkin' his chain a little.
Old Apr 17, 2002 | 07:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya....just a little yank'en.
Good news for Ken is that you were willing to take a shot at it...and it paid off.
Funny though, about the valve...I wasn't aware he was using used heads, I thought he bought them new?
And also yet another reason to degree in the cam, especially when you're not doing this type of thing on a daily basis...heads would have still have to come off I guess if they were bad when installed.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
anesthes
Sep 30, 2015 07:48 AM
Abubaca
Sep 20, 2015 09:35 PM
