Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
'00 SS vs my GT
Old Jan 3, 2003 | 11:10 AM
  #51
5.0mustang's Avatar
All i know about his car is thats its a 331 with a 150shot, gears, nittos, full exhaust and whatever.... Personially, id be very upset if a built my motor from the bottom up, and it got beat that bad by a stock LS1 with a 100shot....
I know of many slow Mustangs also, but you can't judge every one on just one! If that were the case, and you compare to mine, I just found out I was running on 7 cylinders! I know of many 306s with no spray or power adders running 115+ in the 1/4 taking out modded LS1s! It all depends on the car!
Old Jan 3, 2003 | 02:54 PM
  #52
N8Miller's Avatar
How did you know that you were runnin on 7 cyl?
i had that spark plug problem and it was arcing bad. my dad replaced it, he said there was no arcing, but didnt drive it yet. i think that alone should put me in the low 13s and its got more miles on it now too (about 1300 total on 331).
There are some bad azz 306s that are killing cars everywhere. it all depends on how well you match your parts and how well you stick your car to the pavement. that goes for ford or GM. part matching and driving is key.
Old Jan 3, 2003 | 04:00 PM
  #53
5.0mustang's Avatar
When I pulled the wires, the number 7 wire was chaffed (the cover had cracked off) and the number 7 spark plug was so gummed up and looked as though it had not been firing. I had my dad and a semi-pro drag racer there telling me the same thing I thought, and quite a while before the car went away, it was stumbling whenever I got into a little or tried to pass on the highway! Plus I could feel that it was low on power when I put it in 2nd and punched it from about 3000 RPM.
Sometimes even the right parts just need to be freshened up. A friend of mine has a 1990 LX with a B cam, GT-40 aluminum heads, a Cobra intake, 65mm throttle body, 73mm Mass air, 24lb injectors, 1.7 roller rockers, full exhaust, 3.73s and many other driveline parts. He was running 13.6 (his best) to 14.3 (all last year). He finally brought it somewhere and had new valve springs put in, and some other work done and now the car is going mid 12s on his Gtech (which is now mine!). Sometimes cars just don't react like others!
Old Jan 8, 2003 | 06:31 AM
  #54
ArcticLS1's Avatar
How could you not tell one of your spark plugs was loose to begine with????
Back with my old 1991 Z28, one of the plug wires became disconnected and it ran like sh2t and felt like i had mabey half the power... I diffently wouldnt have raced anyone with a car running the way it would with a spark plug not working.. Its also something you should notice is just driving the car normal....
Old Jan 8, 2003 | 01:44 PM
  #55
5.0mustang's Avatar
It wasn't loose, as a matter of fact the spark plug was fine just seemed as though it was not firing, but the wire had been chewed up (I don't know how else to put it) in one area. Believe me the car ran like crap. It stumble whenever you gave it gas, and passing on the highway was a joke. There was definately something wrong when I drove it, and I am assuming this was it!
Or at least hoping this was it!
Old Jan 10, 2003 | 05:08 PM
  #56
CHEVY_EATER's Avatar
Car: 93 Mustang GT
Engine: 5.0
My friend has a 95 GT loaded with every option . He has box stock Edelbrock Performer heads, E-303 cam, 1.7 RR's, Edlebrock Performer intake, 73mm MAF, 70mm TB, and full exhaust. He has ZERO tuning and stock FPR still! He ran a 12.9@111.8 with it on street tires (2.09 60ft) and was breaking loose into 3rd gear. That is with stock bottom end and parts you can just buy out of a catalog. He also has a 93 LX that ran a 12.9@99 all stock motor even the intake, TB, and MAF. He now has Edlebrock Performers, 1.7's custom cam, Bennet upper on ported GT-40 lower, full exhaust, Ppowerdyne SC with about 9psi and ran a 10.81@126 with it on the stock bottom end and T-5.
Another guy I know "had" (it got stolen) a 87 GT with just home ported TFS head, small cam, 1.7's, Victor Jr. intake, 650 carb, on a stock bottem end. Had a T-5 with 4.30's and ran 11.54@119 ALL MOTOR!
Old Jan 10, 2003 | 05:18 PM
  #57
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Yea well my friend has a 85 Z28 with a 305 that runs 10's ALL MOTOR!!
Old Jan 10, 2003 | 05:36 PM
  #58
5.0mustang's Avatar
The thing is he is probably telling the truth, because most guys don't see the potential in the 5.0s on very little parts! Even Mustang owners don't! 12.9 at 99 is some serious traction!
Old Jan 10, 2003 | 09:34 PM
  #59
bigals87z28's Avatar
Car: Check The Sig
yea well i have an uncle that has a friend that knows a guy named john force and his mustang will kill all ur mustangs! hes got a stock 5.0 i think........ hehehehe
anyway... i got one of thes dist. caps on my taur-***.... i was gunna take it off but there was chit load of spiders and spider eggs on the underside of it... it freeked me out.. anyway... i say the LS1 kills the stang cause i wana be different... it dont matter what so and so has with this combo... its what this guy is runnin with his car... i dont think that fixin a spark plug is gunna net hima whole second to beat the SS... i say the SS can runn a good high 12 with even a quality driver... good luck (sort of) and i hope u lose (sorry, u still got a stang)
Old Jan 11, 2003 | 07:36 AM
  #60
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
12.9 @ 99? uhh...no
Old Jan 11, 2003 | 08:54 AM
  #61
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
You have to factor in weight. There is no way(no way in hell) You could get 11's from a 104 trap speed. It is mathematically impossible(unless your running 2300lbs.) I can't compare my car to an n/a car, but figuring in the base weight of a GT(at least 3200lbs.) Your gonna need to trap at least 108 to get in the 11's and that is with a 1.6 60'.
As far as Ford and the 302, the reason the 302 has an advantage is the heads( the symmetrical cylinder heads of the 302 perform better than the 305's, their valve angle is also better than the 23* Chevy's). The Chevy cylinder head is a compromise. The new LS1 heads have symmetrical,cathedral ports(don't have the restriction in them like normal sbc heads).
As to the other guy talking about the 305 not having a stroke(the pipe is getting to you). The stroke is the same in both the 305 and 350 3.48in.
If you want your 11's throw in a 100 shot and be done with it. There is something missing in your combo. A good 6speed LS1 will trap 107 in the 1/4. You definately have your work cut out for you. Third gear in the LS1 is a killer. If you can manage to actually get em off the line hope you have a top end charge to hold him off cause he will be coming for you up top.
You may see a 12.7 or so with a good 1.7 60' but not much more if you are pulling through the traps at 104mph. And I can almost guarentee that with a 1.6-1.7 60' you will lose maybe a mph or two. Your speed will go down but et will reduce also. With a good 60' You could pick up close to .9 with your combo right now, which would put around the 12.9-13.0 range.
If he is a better than average driver he's gonna take your lunch money!!!!!!!!!!!
Old Jan 11, 2003 | 11:28 AM
  #62
5.0mustang's Avatar
We know that now his car is slower, but if he gets it sorted out he should trap well over 110, which is good for 11s with a 3200 lb car and a low 1.7 60'!
bigals87z28, I am just going by what his combo in a good tune will run! If you don't want to believe what the Mustangs can do (typical of 15 second Fbody owners) then I hope you get surprised the next time you are next to a stock motored car!
The 305 can be made fast, yes, but it does take quite a bit of work. 11's are very possible (as baddest305 has shown) but the motor will be maxed out shortly after, and I don't know how many stronger aftermarket blocks there are for the diehard 305 guys!
I think with the right tune the Mustang should walk all over the LS1, and I know that may be hard for the LS1 lovers here to believe, but it is true!
Old Jan 11, 2003 | 11:59 AM
  #63
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
If he gets it sorted out. That's gonna take some tuning to pick up 6 mph or so. Fords can be made quick as with any car. If you think a 305 can't me made to run down any modded stang get a set of heads port the intake and slap on a procharger and any 305 will muster enough grunt to beat up on many a car.
Bottom line is people take Ford threads with a grain of salt! The guys on the board(a GM board) do not like fords so you can understand the hostility.
Old Jan 11, 2003 | 12:26 PM
  #64
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Exactly!!!!! Also he is one of those guys my friends car runs this and that but he has mods and only runs 13's high 13's at that and with few mods that I did to my 305 when it was stock went low 13's stock bottom end and heads...........PLUS FORDS ARE NOTORIOUS FOR BLOWING HEAD GASKETS BUT HE CLAIMS NOT MANY DO !!!!!!!!!!!!LOL
Old Jan 11, 2003 | 12:34 PM
  #65
Car: 93 Mustang GT
Engine: 5.0
Originally posted by Nic
12.9 @ 99? uhh...no
UHH..ya. The car had weight removed and hooked awesome. Go on his site and ask or look for yourself if you doubt it.
Old Jan 11, 2003 | 12:36 PM
  #66
Car: 93 Mustang GT
Engine: 5.0
You obviously know nothing about cars period. If you don't belive it go to my friends site in my sig and ask around or take a look at the timeslips in there.
Old Jan 11, 2003 | 12:39 PM
  #67
Car: 93 Mustang GT
Engine: 5.0
Where did that one come from? Something you made up? I've NEVER had a single headgasket problem with my 5.0;s or my friends that I put together. Just like any other car..if the engine isn't tuned properly, things break/blow. I better go put my boots on...getting deep in here!
Old Jan 11, 2003 | 01:32 PM
  #68
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
You FORD guys are too much!!!!!!!
For the statement that I don't know anything about cars well JUNIOR ANYTIME YOU WANT TO RACE LET ME KNOW!!!!!!!
We can meet in the middle like E-TOWN or something anytime!!!
So pipe down little guy!!!!! Also apparently you or your friends aren't making enough power to blow the head gaskets!!!!!
Plus my statement about getting the boots out well since I have been reading this crap mine been on!!:lala:
Old Jan 11, 2003 | 01:41 PM
  #69
Car: 93 Mustang GT
Engine: 5.0
Your are a TOOL, no getting around that. Power doesn't blow headgaskets, improper tune does. I'm running over 2 degrees advanced timing with 12lbs of boost on my friends 91GT. I can do that and still have ZERO problems since I know how to adjust fuel pressure and run a good mix of 110/94 gas. I'm not a "Ford guy". I'm a CAR GUY! I work on many other cars including imports. I just hate morons that don't know anymore than a kid in elementary school. Come on over to my friends board or hop on over to www.corral.net and see for yourself. You need to get out of your cave...
Old Jan 11, 2003 | 01:46 PM
  #70
Car: 93 Mustang GT
Engine: 5.0
I'm not a kid so your WAY off with that LAME remark. BUT..Age doesn't equal knowledge, it just means your older! So..what kind of beast do you have? I'm sure I can find some cars to race you where you live.
Little guy? Wow...thats original.
Old Jan 11, 2003 | 01:52 PM
  #71
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
86Z28...............Why don't you race me since your the chevy-eater how original!
Old Jan 11, 2003 | 02:01 PM
  #72
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
[QUOTE]Originally posted by CHEVY_EATER
Your are a TOOL, no getting around that. Power doesn't blow headgaskets, improper tune does. I'm running over 2 degrees advanced timing with 12lbs of boost on my friends 91GT. [/]
1st off I was sarcastic!!! 2ndly I don't know what it is with you Ford guys but you always refer to a friends car!!!!
Now why don't you get out of your cave and build your own car instead of a friends car!!!
So when your aloud out of your cave get ahold of me so we can setup a race with your car and I'll show ya how much I know about cars and tuning!!!
Old Jan 11, 2003 | 04:17 PM
  #73
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Exactly!!!!! Also he is one of those guys my friends car runs this and that but he has mods and only runs 13's high 13's at that ........
You started the "my freind runs this or that" thing when you posted ......................
Old Jan 11, 2003 | 04:18 PM
  #74
Car: '87 Mustang LX
Engine: 5.0
.................this.
How do you figure? I have buddies with mustangs and I know that they can fly with the proper setup but I can't see how you think he will hit 11's as it sits....My one buddy finally got into the 11's but this time he went with a 351 windsor after numerous attempts with couple different combos like 306, 331, 347 just to name a few....Also the reason he had some many different combos is cause something went wrong with each.....cracked a piston (HYPER) don't ask how.........oil pump drive rod.......head gaskets a couple of sets........So I would like to know what your basis is for your claim........
Old Jan 11, 2003 | 04:43 PM
  #75
Nic's Avatar
Nic
Engine: 5.0L
This one went down hill very fast...
Old Jan 11, 2003 | 04:52 PM
  #76
Nic's Avatar
Nic
Engine: 5.0L
While we're on the "my buddy this..." topic....
My buddy ran 11.6 in his LX with a 306 with stock heads, cobra intake, and a .500" lift cam
Old Jan 11, 2003 | 06:21 PM
  #77
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
You should be banned! you mentioned the c word(corral.net).
Next thing you know you'll be trying to get the guys to go to a Ford dealership when does it end? Just because the F-body is dead doesn't mean us loyalists are gonna switch.!!
Don't take it to heart. Life isn't permanent, have fun!!!!!!!
