who will win 84ta vs 86mcss
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
My money would be on the Monte Carlo SS. Main reason is the fact that the 1984 HO 305 wasn't really that powerfull. The 305 HO in the Monte Carlo was post 1985. There were huge torque increases and they had alot more power stock than the 1984 HO 305. The bird is lighter but not by enough.
If I am wrong someone tell me. I am proceeding under the idea that the 1986 Monte Carlo SS would have a 305TPI similar to the 1985 and up TA's and Camaro's. Is this the case?
Car: 1990 GTA
Transmission: manual/t56
no stock montes were available with tpi. It probably has a quadrajet. I'm leaning towards the firebird because I think they're a little lighter. gotta love a monte though. either way it should be a good race.
Well I thought the Monte would have had a LB9 or a L03 instead of the LG4. If it's got less HP and TQ then there is no way in hell he could outrun the lighter F-body stock.
i used to have a monte SS, great car, and it ran hard for what it was. i beat quite a few stock 305 f bods. it was awesome on the highway.
but i had little stuff done, i reworked the carb a little, super coil and k&n. that coil actually helped alot.
adam
adam
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
If I'm not mistaken, the Monte SS came with 3.73's. What did the TA come with? The 3.73 are what helped the Monte with that weak 180hp paper weight.
Transmission: Automatic!
The MCSS will have 3.73s with the 2004r like mentioned, with the L69. Should run a 15.5-15.9 if its running well and stock.
The Trans Am will have lower numeric gears so the MCSS will beat it off the line, the Trans Am should come back though slowly and it would be close either way. The weight difference might be 200 lbs.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Car: 97 Z28
Transmission: A4
The auto Fbodies came std with 3.42's with 3.73's optional. So, if we assume the T/A has 3.42's, I don't think either car has a clear advantage off the line given the crazy low first gear of the 700R4.
As for weight, my loaded Iroc weighs 3400lbs, 3600lbs with me inside. The GTAs are the heavy wieghts of the 3rd gens. I would think that the pre-'85 cars would weigh less considering the smaller GFX, wings and no TPI junk.
I was under the impression the only f-bodies with such high gear ratios were manual, not automatics. The Trans Am I parted out, a 87' WS6 with the LB9 had 2.73's. I also didnt think any f-bodies had 3.73s, just the option on the 5 speeds could be 3.23's. Id rather have the weight of the TPI *junk* than the slightly lighter carb setup
. Most MCSS's weigh about 3500-3600 depending on options. The base weight with no options (minus driver) weigh like 3,350-3,400 lbs, but most are relatively loaded with power windows/AC and in the last few years, t-tops.
. Most MCSS's weigh about 3500-3600 depending on options. The base weight with no options (minus driver) weigh like 3,350-3,400 lbs, but most are relatively loaded with power windows/AC and in the last few years, t-tops. Member
Car: 97 Z28
Transmission: A4
The gear ratio info is all in the tech data on this site.
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
my car has 3.73 and its an automatic.....i think it was the G92 package that got these gears in the 84TA HO
also i weighed my car.......3700lbs with me and my system in it......
Hotrodboba400
Dec 10, 2019 07:07 PM
Angie Coots
Sep 23, 2015 07:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
