Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
92RS Vs. 02 WRX
Old Jun 8, 2003 | 09:56 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
92RS Vs. 02 WRX
Well what do you think? I don't know what these cars run. The WRX is completely stock.
I guess these cars are great for launching with their awd. But with my new TC, 3.70 rear and the low end TQ of the engine. I think I could take it off the line.
After that I dont know.
Old Jun 8, 2003 | 10:24 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Not even close. Unless he is a bit slow reacting and can't drive the WRX will nail you all the way through. I raced one for ****z and giggles and ya, i looked like i was standing still. Granted you have gears and some decent mods, but not enough power to beat the WRX. Sorry.
Old Jun 8, 2003 | 10:28 PM
Car: 92' RS
Engine: LO3
Actually its a she. The GF of I guy I have class with. Any idea what these things run in the 1/4?
Old Jun 9, 2003 | 01:10 AM
89transam's Avatar
I have heard 14.2 stock....I could be wrong
Old Jun 9, 2003 | 08:17 AM
bigals87z28's Avatar
Car: Check The Sig
its a chick? ... is she a good driver? if not, she could run about high 14's but its not hard to launch a AWD car. anyone that can drive stick could probably do it. Just run it up to 3-4k and then drop the clutch. If shes good, low 14's wouldnt be to hard for her. i see most running sock 14.2-14.8... either way, your toast.. sorry.
Old Jun 9, 2003 | 09:01 AM
MdFormula350's Avatar
of friend of a friend has a wrx sti and that thing hauls major butt. like low 13's all wheel drive turbo is something to watch out for.
Old Jun 9, 2003 | 09:03 AM
SPOOM's Avatar
I'm sorry, but it's not really quite that simple. Have you ever tried to launch an AWD turbo car? If you used your method, you are almost certainly guaranteed a huge bog (then you'll fall out of the sweet spot of the powerband and have to wait for the turbo to spool back up). It's not really the fastest way to get off the line.
Since you will not spin at all (unless you are modified enough to burn all four tires off the line) the best way to get off the line is to bring the revs up to 5500-6000 or so, then simultaneously floor the car and quickly slip the clutch. This prevents a bog, and assuming that your clutch is in shape, gives a huge kick-in-the-*** of the line (first gear is literally over in the blink of an eye).
This technique is based on a number of turbo AWD DSMs that I've driven, but I imagine that it's a similar technique for WRXs. It's not as easy as you might think, but it's still much easier than launching a turbocharged front-driver.
Old Jun 9, 2003 | 09:06 AM
Car: Check The Sig
Md, an STi and a reg WRX are two different worlds. the STi is the "Cobra" version of the WRX. its also around $8k more. It comes with a 2.5L turbo with a bigger intercooler and more boost to jump it from 220ish in the 2.0 turbo, to around or over 300hp. Also comes with horrible wing and gfx. What it doesnt come with is a radio and i belive HVAC is deleted were you only have heat, no AC. the 2.5 turbo can only be found in america. Even with imports, there is no replacement for displacment.
Old Jun 9, 2003 | 12:15 PM
89transam's Avatar
Of corce there is , just get a bigger turbo
Old Jun 9, 2003 | 12:22 PM
Car: Check The Sig
or a bigger bottle of naaaws...
Old Jun 9, 2003 | 05:42 PM
Car: 92' RS
Engine: LO3
Hmm well I guess I won't antagonize her too much then. At least my car looks sounds a lot better.
Old Jun 9, 2003 | 09:15 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
A wise man once said this!!!
Yes, the bog has happened many time to many people (me included) and can actually hurt more than spinning. Basically if you pull any car out of it's power band you kill it, especially a turbo car.
Old Jun 14, 2003 | 02:30 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Hahaha.
My friend beat a turbo WRX in his parents GMC Venturer(band new)
ROFL it was funny. Stupid idiots that cant drive.
I swear the guy launched at like 7krpm.
Old Jun 14, 2003 | 09:15 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
have you guys gone mad unless you do mods to those cars their actually not all that i beat one N/A in my Rs at the track i think it turned like a 15.6 or something i turned a 15.44
Old Jun 14, 2003 | 10:21 PM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Do you mean he was N/A or you were N/A??? Because if you meant he was N/A he doesn't have a WRX, but an RS and those are very slow!
A properly driven WRX will be a low 14 second contendor!
Old Jun 15, 2003 | 11:48 AM
BigErns90IrocZ's Avatar
Yeah, with a good launch a WRX is easily mid-low 14s. 227 or so hp with AWD and a 5spd is a decent combo.
Old Jun 15, 2003 | 03:13 PM
Car: Check The Sig
problem is, most WRX drivers arent decent... they just drop the clutch and let awd take control... most i see run from 14.4-15.2
Old Jun 18, 2003 | 11:22 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
The new STi's are awesome machines...only America and Canada got the exclusive 2.5, whereas the Japanese version is actually the slower....2.0 still, I believe. It has a manual, water-spray type intercooling that is awesome to watch...just a button, then *pssshhhh* and steammmmyyyness! Plus the ability to set the rears free in a hard braking/cornering/rally situation is very cool...and I don't care what anyone thinks, that hood is awesome! 300+ hp stock, if I remember correctly.
Old Jun 19, 2003 | 08:43 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I love the WRX and would be proud to own one.
Old Jun 19, 2003 | 12:39 PM
Arent the new STi supposed to be rated @ 300 HP? I might be wrong on that.
Must people that try to race WRX are kids in cars mommy and daddy bought them. Such as a time a kid(dad owns exotic car lot) took an Audi A4 Quattro off the lot to take to a school dance and went cruising afterwards. He raced a late 80's RS L03 when me and my freind were right behind him, he only had about a car on the RS by 45 or so, and all the RS had was exhaust. Most people don't understand that a high RPM dump is crucial with a turbo and AWD or you are not going to hit mag times for the car. My freind thinks that his 95 Talon TSi AWD 5spd will run high 14's w/o dumping the clutch.
Old Jun 19, 2003 | 01:37 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
I just wanted to reiterate you don't DUMP the clutch or you'll BREAK something if you don't bog like mad. You SLIP the clutch. SLIP not dump.
Dumping the clutch is bad.
Slipping is good.
Dumping the clutch is a large contributing factor to why many WRXs would lose their transmissions before (so I hear) they beefed them up this year. A properly slipped clutch is a huge kick in the *** and allows you to take off like a bat out of hell (and makes your windshield wipers come on;p). A dumped clutch makes the car go vrroWrrrrr and you wonder what the hell just happened and believe that all these stories you hear about those sick 60' times in awd cars are wrong.
I just wanted to be sure that this was clear to everyone.
Old Jun 20, 2003 | 01:11 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
How would my car hang against a WRX not a STI? Mods are in my sig link.
Old Jun 20, 2003 | 01:53 PM
Azure's Avatar
trans87 - nice car, but those gears will be a killer...
Old Jun 20, 2003 | 03:13 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i ran a couple at the track a while ago. of course they ripped me a new one outta the hole, but after that they didnt gain any. best was a 14.2, and worst was a 14.6
Old Jun 20, 2003 | 03:23 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
AWD is NOT undefeatable. i regularly holeshot these cars at the track. the look on these guys faces when we get back in the pits is priceless.
TPI + drag radials + stall converter = WRXs seeing Corvette taillights
Old Jun 20, 2003 | 09:46 PM
trans87's Avatar
Thanks. Yea the 2:73s just plain suck so they are going to be changed next. Even still with the power I am pulling should I be able to take a WRX?
Old Jun 25, 2003 | 02:41 AM
Berlinetta82's Avatar
I saw a dark red one with gold wheels a few nights ago and was blown away with the sound of that thing. I dont know if it was the Sti or not but it had an insane "european" sound to it. SOOOOOO smooth but throaty sounding and not one bit ricerish. Almost unexplainable. Like WOW! Does anyone know if that is what the Sti's sound like or not?
The WRX/STi is by far my favorite import. Beautiful cars IMO.
3.8TransAM
Sep 17, 2015 02:16 PM
tero
Aug 15, 2015 02:47 PM
92RSB4C
Oct 18, 2001 05:49 PM
jtmiller92
Jul 12, 2001 08:08 PM
