Beat a Z06 from a roll by 2 car lengths
Car: 1985 Z28
Transmission: 700-R4
Was cruising late night trying to get a bite, when a Z06 pulled up beside me and floored it, he had a good head start on me, but I lost traction when I downshifted to second...he had me till about 85 mph and I really started gaining when I shifted into third.....I didn't ever shift into overdrive and let off stepped out and had a victory cigarette. He would have owned me top end no doubt but I got him
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Yup, those Z06's are not as tough as people make them out to be...not saying they aren't fast but they are far from invincible(stock that is).
Guest
Posts: n/a
Originally posted by Teal91rs
Your jokeing right?
Your jokeing right?
On a side note, they'd kill me from a stop on these horrible tires I've got. I can't even run a 13 with them.
Car: 1991 camaro RS
Engine: 305 Carb
Nope. I've got 277 hp at the wheels and my car weighs 2,600 lbs with me sitting in it. I trap at 106mph at a mile above sea level. I'd probably be in trouble down at sea level, but not so much up here.
I was looking at a GM Tech magazine, they got a professional drive to put a new ZO6 in the quarter, after a few Good tries. The ZO6 with your average drive traps at about 116mph. You'll get slaughtered!
Guest
Posts: n/a
Not at this altitude I wouldn't. AND I'm not really worried about going up against any professional test drivers.
Don't give me crap about wanting to race a ZO6, I trap 10 miles an hour faster than stock C5s, what else am I supposed to want to race?
Guest
Posts: n/a
Originally posted by Cameron
a honda del sol
a honda del sol
106mph at that elevation would put you very close to Z06 performance. Even with similar power/weight, I'll bet the Z06 jumps (V8 instant torque vs boost lag) out a car on the go and you'll be dead even the rest of the race. Add in bad tires and FWD and you had better hope to find a bad driver
Guest
Posts: n/a
Oh yeah, in a race, there is no such thing as turbo lag. There is the minimum boost threashold, but that only has to be overcome once, in first gear. Even that isn't that big of a deal because first gear is short enough. Luckily, first is so short that there isn't enough load on the engine to even hit full boost in first.
Guest
Posts: n/a
I'm talking about a drag race. You are absolutely right though. Once you hit full boost once, you should remain in boost every time you shift. Every car I've raced from a role has gotten the jump, but if you start in the right gear, then it's really not much. It takes about a second.
I don't even really plan on getting one to race me from a stop though, most likely from a roll down the highway or something.
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I've raced many, many turbo cars, and they ALL had some lag. Stock singles, twins, sequentials, and many aftermarket setups. You just can't make instant boost, I don't care what engine/turbo combination you're running, gear, RPM, etc. Many guys are even brake boosting from a roll (seems to be most popular with the Supra guys), and that helps, but still doesn't eliminate all lag. Even when outgunned by a turbo car, I can still jump a car or two lead before they start to pull.
my friend in his rx7 was able to get about 4 psi reving with the clutch in. and would try to launch while hitting a little boost
Guest
Posts: n/a
My buddy with a Neon (went 11.9 @ 110 in Texas) launches in boost as well.
I never said that the other guy would have to mess up for me to stick around in a race.
I think you just sound threatened. Also, I just said I wanted to race one, I never said anything about walking them or anything. What a little girl you are.
Like this guy? lol
I can take some pictures of my dyno sheets and recent time slips if you were talking to me. I'll pick up my camera from work tomorrow.
Originally posted by Kevs87Z28
stick to imports leave the big guns to the big boys.
Originally posted by akbar347
Just be warned that z06's have an insane high end (and they trap a little higher than 106...) I'd also like to see a dynosheet or timeslips.
Guest
Posts: n/a
www.dynopro.com
Go to the Mile High Horsepower list
When the site is updated (whenever that will be) I will be in the #15 spot right under Chris with the RSX. I think he was running 13.00s with his drag radials. Hmmm, that might have been in the supercharger RSX though.
Anyway, in the mean time, you can all check out the top list of Camaros and F-bodies, and laugh at the huge lack of torque the Hondas make.
Yes I'll still be posting my dyno sheet and time slips.
Car: 1991 camaro RS
Engine: 305 Carb
Guest
Posts: n/a
Originally posted by del91_305
I dont know what C5 vette your talking about. But ive never heard of one that traps at 96 mph. But the C5 vettes that i know of trap around 110mph, and thats a few mph faster than you. Yeah your car is fast i will admit, but you underestimate the C5 vette.
It's like high altitude was just invented yesterday talking to some of you guys.
Guest
Posts: n/a
It does give me an advantage. Since the turbocharger is driven by exhasut gases, and the power output is determined by a set boost level, it can spin faster to compensate for the descrepency in air pressure from sea level. A supercharger is belt driven, thus it can't just spin faster, and an N/A motor can't just decide to breathe better to make up for the lack. So, while N/A and superchargered cars will lose somewhere around a second in the quarter mile, turbochargered cars only lose around half a second. Turbo cars have a definite advantage at altitude, it's even more apparent when driving in the mountains.
If I were at sea level, we wouldn't even be having this conversation.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I have to say...
READ WHAT HE TYPED, he is a mile above sea level. Take a LOT of time and mph off the Vettes you have seen and then compare. My 107-108 traps now would barely be 100 if even that at that sea level. I have the same rwhp numbers (272) but weigh 600 lbs more!
Guest
Posts: n/a
I talked to some kid once (this guy looked about 18 years-old) who had a ZO6. It was all beat up (nice big hole in the front bumper) and had the ugliest 20 inch chrome wheels I've ever seen. I asked him what it ran stock, and he said,
'see that guy over there? He's my real good friend, and he drove this car at a 13.1 @ 108mph.'
ME: "With those wheels?"
'Yeah, that was with those wheels on, he's a real good driver and my best friend.'
I don't remember why he wasn't driving his own car, but I do remember that him, his friend, and his story didn't sound exactly true. Those numbers sounded all right to me, but not with the 20's on there. I don't know though, a couple of people I talked to didn't seem to think the story sounded too fishy. When does the C6 ZO6 come out anyway?
Car: 1991 camaro RS
Engine: 305 Carb
Guest
Posts: n/a
No one ever said that a ZO6 only traps in the high 90's. I said stock C5s trap in the high 90's, and I trap significantly higher than that, so it's a natural progression to want to race a ZO6. I guess you didn't read what I typed.
What 'math' are you talking about here anyway?
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Well then think of it this way, The ZO6 traps around 116 then at that sea level it probably traps around 105, yet that is STILL FASTER than 96MPH, Right? Do the math, its not that hard, we all have an education right?
1 second is HUGE! It's an eternity! At 100 mph thats roughly 10 car lengths! Give me 1 full second jump on another car and I'll have several lengths on him. So not only do you have to accelerate quicker than the other car just to stop his pull, but you have to accelerate at an even quicker rate just to catch up. The ability to catch up and pass another car after the other car takes the jump shows a large difference in acceleration rates, much more so than beating a car by the same amount from an even start.
And stu is right about elevation not affecting boosted cars as much. Same goes for alternate fuel cars like the alcohol burning cars. They only run air/fuel at around 6:1 I believe.
EDIT: next time someone calls BS about the times or traps up there, make sure you point out in large, bold font you're a mile up. Maybe that will make a point... I believe five7kid runs near you, but I don't think he visits this board much.
Guest
Posts: n/a
Let me clarify. When I said it would take a second, what I meant was, at most, and to full boost, not before you move at all. Sorry I didn't clarify that.
Also, you may drop a few psi when you shift, but you don't fall out of boost. That's one of the few reasons that the BOV is so important. It would suck very much if you fell out of boost everytime you shifted at full throttle.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I agree, boost is not an on off switch, and that slight second when shifting (of a little loss in boost, not a complete shut down) is not going to be a huge deal. Automatics are better for boosted cars, but doesnt mean the sticks cant run right with them!
Engine: 355 Carb
i dont know about anyone commenting here but when everything is said and done no matter what a car runs or what body kit or r icey parts it has on it i just dont care about integras.
you could run 7s and i will still perfer my mostly stock z28 over any integra. the styling is just not for me and i think that one movie we all know just gave people the idea that those tiny cars are so cool when i dont think they are anything at all no matter the degree of modification.
bottom line i think they suck.
Guest
Posts: n/a
Since when were we talking about looks? There are a lot of cars I'd rather have than my Integra. Whats all this BS about wings and body kits, do I need to post pictures of my car again? I'm taking pictures of the dyno chart and timeslips right now.
P.S. If you ever admit to liking a car besides your own, that's the moment when you realize that your **** stinks just like everyone elses. Your day will come.
Guest
Posts: n/a
Can anyone even see this?
I know these are small, but I will make them bigger once the gallery on my home site is fixed, it's fubared right now. Anyway, the first slip is the 14.2 @ 106 and the second one is the 14.1 @ 104. I'm on the left on blth slips. The car running a 13.5 @ 107 was a supercharger GT Mustang 2001+. The 16.00 was a WRX, must have been an automatic.
The first dyno sheet is the one run I got without the CEL coming on and the air fuel ratio.
The second one is the first pull untuned 250whp, and the 7th pull, 277whp.
Here is the car again, just in case you forgot why a ZO6 wouldn't give me the time of day in the first place:
Guest
Posts: n/a
Plus, as you can see here, I've been a horrible driver this year. Last year I could cut some .060 lights, but not even close this year. With these tires, the best 60' I've ever gotten was a 2.301.
This one was the latest 106 trap. My best was a 106.87mph. That particular run was a 14.012.
damn talk about a sleeper.
