Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
82 Camaro vs 68 Chevelle
Old Oct 3, 2004 | 01:18 PM
  #51
82CrossfireInj's Avatar
Car: 82 Crossfire Injected Camaro, 1987 Mazda B2000 Pickup
Engine: 383 V8's
Transmission: Streetfighter TSI
right now im more concerned about how much power i can put out spending the least amount of money than my opinion, i have driven a carbed Maro, and have driven a TBI 'bird, and i dont prefer either one over the other, just what i can get more power out of, cheaper
Old Oct 3, 2004 | 01:23 PM
  #52
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
hmm more power cheaper = carb 9 times out of 10
Old Oct 3, 2004 | 01:28 PM
  #53
Engine: 383 V8's
specific brands? would it also be smart to have the 383 cammed too?
Old Oct 3, 2004 | 01:32 PM
  #54
THEGENERAL's Avatar
what do you mean cammed??
do you mean upgrading the cam to a larger cam .......that all depends upon your setup of what you want to run
you dont want to go throwing parts into an engine and end up with alot of high dollar parts that wont run any better together than it did before ......you need to make sure that everything is matched together ...and works in accordance to the other parts...
Old Oct 3, 2004 | 01:35 PM
  #55
ljnowell's Avatar
Dont get too much cam for the rest of the setup. It will only hurt you. As far as a carb, basically everyone on here will say Holley. In my opinion before I used a holley, I would switch to a HEI vacuum advance distributor and a non-CC Qjet carb. They work great. If I were going to be buying an "aftermarket" though, I like edelbrock. But beware, if you buy an edelbrock you will be treated as the black sheep of the site.
Old Oct 3, 2004 | 01:36 PM
  #56
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah, packages like edelbrock provides is matched.
Just get a intake with a range like 2500-6500 rpm
Then get a cam to match. What are you using? Hydro-roller?
Rollers on 383, I d say something like 230/240 range and around abit over .500 inches of lift. comp cams make an extreme energy cam like this. the 276hr is not bad either-- 224/230. Either one would work good. Its probly best to be abit small than too big LOL
Old Oct 3, 2004 | 01:37 PM
  #57
THEGENERAL's Avatar
BAAAA! BAAAA! :lala:
Old Oct 3, 2004 | 01:59 PM
  #58
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Originally posted by Orr89RocZ
Depends on your budget or goals. You can make decent power with upgraded TPI components. You can make greatest power with super ram, miniram, stealth ram, or carb.
Do you like fuel injection or carbs? just an opinion thing. Carb/intake probly be alot cheaper than upgraded TPI or superram/miniram. A stealth ram is close in same price range.
He'd have to buy the -entire- system. He'd be looking at well over $1000 for all the modifications he'd have to make, with a carb the cost of entry is MUCH lower. Under $500 most likely.
Old Oct 3, 2004 | 02:02 PM
  #59
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
The upgraded TPI and superram/mini ram would be running over 800 dollars +
But cant you get a stealth ram and the fuel rails for under 500? and get TPI harness for 100 bucks on ebay? Might not be too far out of the carb price range. Just got to shop around. LOL
Old Oct 3, 2004 | 02:09 PM
  #60
ljnowell's Avatar
Its still not going to be able to beat the carb, for outright peak power and RPMS, in the same price range.
Old Oct 3, 2004 | 02:22 PM
  #61
THEGENERAL's Avatar
not to mention tuning difficulties with a carb they are alot easier to deal with ....
Old Oct 3, 2004 | 02:43 PM
  #62
ljnowell's Avatar
Be careful, someone will step in, probably someone who wasnt alive before EFI and tell you that its just as easy to tune. I agree with you though, nothing beats the carb for simplicity.
Old Oct 3, 2004 | 03:15 PM
  #63
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
Burning chips is another $300+ to invest not to mention the loggin laptop at around $300 for an old POS so that in addition to the fuel pump, sensors, injectors, distributor, speedometer, not to mention incidentals and of course the fuel rails, harness, throttle body and intake...
It's not 'cheap' to convert a CFI/CC Carb car to an upgraded tpi system. Not difficult but not cheap either. CFI to non-cc carb is MUCH cheaper.
Old Oct 3, 2004 | 03:23 PM
  #64
Engine: 383 V8's
by "cammed" i meant, newer, better cam, im running a pretty worn out Comp right now, when the 383 was built it was built custom, not all the parts were new though, and the cam was pulled out of a corner in his garage, but i know a man who works for Comp here in Memphis, so acquiring a new shaft wont be a big deal...
but Ive got you guys saying Holley, and my friends dad has a 1923 T-Bucket with 2 Demon carbs, and they run amazingly great, and im not sure at this point to go with Demon or Holley? what do you guys think about Demon
Old Oct 3, 2004 | 03:35 PM
  #65
Inwo's Avatar
Engine: 2.0 turbo
Transmission: m5
The guy who designed Demons used to simply modify holleys and still many of the parts are similar although I think he manufactures all his own parts now. They're a bit more reliable than regular Holleys inasmuch as you don't have to constantly play with the jetting when it gets colder or warmer out. Edelbrocks you can just about set it and forget it, they're ideal street carbs. However if you enjoy messing with your carbs every week or two I'd get Demon. They're awful pricey though.
Old Oct 3, 2004 | 03:39 PM
  #66
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I hear those demons are great carbs but alittle more expensive than other carbs. Both are great brands tho. It just matters what cfm you get to match intake and cam. Whats your power goals and what heads/compression you running? i am assuming you got a regular hydraulic flat tappet cam? From this you can get an idea of what you need. The rest of the carb guys can help you out alot more than i can. Try the carb boards.
  #67
Engine: 383 V8's
yeah they are high priced, still again, i am just running my options
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
