89' Trans Am vs. 91'Firebird
Car: 1991 Firebird
Engine: 305 tbi
He says that his can beat mine just because it's a Trans Am. We can't race yet because his is not running right now. We both have the TBI and a few mods. He bought his with 3 inch pipes and no cat. Mine has a k&n open element and a new muffler. Who do you think would win. I think it would be pretty close myself. What are your opinions.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
If all else were equal (including driver ability), I'd say he'd have a slight edge over you due to the 3" exhaust. However, if what you said is true, it's obvious he's not a very experienced driver so I'll say it could go either way.
EDIT: Actually, if I were a betting man, my money would be on you. Formulas are a lot lighter than Trans Am due to less exterior dressup. That, combined with the fact that he's probably not a good driver, will give you a small advantage.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yeah i would bet on you do to the fact that your probably quiet a bit lighter. but that exhaust is going to give him an advantage too. only one way to find out, let us know how it goes.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by k&n
By the way, I'm getting my cat taken off and i'm getting 3 inch tips next week if either make a difference.
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
LOL..... BTW, the ground effects on an 85-90 Trans Am weigh 14-16 pounds all together. Its not enough to make any difference at all. Anyway, Im voting for the TA.
Car: 1991 Pontiac Formula
Engine: 350 C.I
Transmission: 700R-4
Re: 89' Trans Am vs. 91'Firebird
I thought the TPI 5.0 was the base engine on the T/A's?
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Car: 1991 Firebird
Engine: 305 tbi
You're correct. I've been meaning to change the Formula part. I found out a while ago the guy just slapped Formula decals on it and called it one. Anyways both cars have T-tops, but he has power windows and locks.
Car: 2001 Firehawk - SLP Longtubes
I loved my old LO3. Not because it was fast, but because it was reliable and easy to work on. My LB9, L98, LT1 weren't nearly as reliable nor as easy to work on. I ran that car hard for 140K miles. It was still running perfect when it was totaled about 10 years ago. As to the race, I would say it comes down to driver and state of tune. You both probably have the 3.08 and peg leg rears. In all due respect however, you'll need a sun dial to time this race. It's gonna be slooooow. Good luck, have fun and be safe.
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
ide say the 91 will be faster,if it is a lower gear rear end,if both cars are 305/5speed,it will depend on who gets the better launch,both cars 305 TBI should be around 190 horse ,if both are stock,if they are both tuneport 305,the 91 would be 230horse,and 285 foot pounds of toqure,and your 89 would be 225 horse if it was tuneport,with a 5 speed.the reason i say the 91,is because if its a firebird or formula,they are lighter than a ta.
Engine: 4 cylinder
Although you could order the same options for the Formulas as you could the T/As, chances are there are less of them on the Formula since it was the "plain jane" of the three models. Possible weight differences there.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I would guess the 91 bird, it really should have less lbs ( smaller sway bars) often the plain jane birds got skinny tires ect, it all helps. if you can get him off the line and shift at your correct rpm then you should have the race. who ever gets the best launch should win
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Allen
