Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Who would win and why do they bother?
Old Mar 9, 2005 | 08:45 PM
  #51
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
1987 IROC-Z 305 Auto O/D N/A lbs 3250 lbs
1987 IROC-Z 350 Auto O/D N/A lbs 3341 lbs
one thing those two have same options except engine. plus your stupid im just going to make you look dumb now a 305 is not a 350 the blocks are different you cant take a 305 block and make a 350 you dumb idiot just becuase they look alike doesnt mean they are look it up.
Old Mar 9, 2005 | 08:56 PM
  #52
stu's Avatar
stu
Wow, I can't believe how dumb you just made him look.
Old Mar 9, 2005 | 09:03 PM
  #53
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Easy on the name calling. It is uncalled for and against board rules. I wouldn't be the one calling me stupid on something you are so lost on.
I am well aware of the differences in the blocks. Not once did I say that they were the same. I said a lot of the parts were the same. Maybe your research will tell you that. Here I will go ahead and fill you in on some of the basics that you will find in your research. I doubt you will tell me anything that I don't already know.
What is different
1. The bore sizes are different.
2. The water jacket thicknesses and locations are different.
3. The pistons are larger in a 350 (see number 1)
What is the same about them.
External dimensions
Bore spread
Accessory holes
Cam style
Rod design
Crank design
Bearing design
Head style
Lifter style
Valvetrian configuration
intake maifold mounting
exhaust port location
deck angle
They both evolved the same since 1955. That means when the 350 recieved a single rear main, so did the 305. When the 350 went roller, so did the 305. Most parts came out of the same batch. Why do you think engines are given a generation notation? They vary the egnines applications with different bore and stroke combos. It would cost to much to make an entirely different motor for each and every vehicle.
You do know that TPI was never designed for a 350 don't you? Then how can they use it on it? You do know that the G92 L98 and LB9 had the exact same cams don't you? I use an 350 LT1 cam in my 305 TBI. You know how I can do that; because it is a roller cam or the same exact design feature that is used in Gen I and II motors. I really don't want to have this discussion with you. We have already gotten off track.
Even the machine shop cost for rebuilding small blocks are the same. The same tooling and procedures are done. It is actually cheaper to rebuild a 350 than a 305 for that very reason. Because people want to maximise their HP per $ spent.
Old Mar 10, 2005 | 02:14 PM
  #54
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
There are alot of stock cars in japan, 4 and 6 cylinders, that go 12's from the factory with a good driver. some examples are the Skyline, Sylvia, 180SX, and laurel.
The hot thing now in the JDM-USA world, is to ship one of those motors over (SR20DET, CA18DET, RB25DET, RB20DET etc...)
and drop it into a similar (or not) JDM car, like a 240SX or Nissan hardbody truck, or even a lexus.
My 240SX, with just the SR20DET motor, NO MODIFICATIONS just dropped the motor in. And I mean nothing else is done, even have the factory steel hubcap rims.... I went 12.9 @ 113 on a cold day with a 2.2 60' Time. The car makes 267RWHP, and weighs 2650Lbs without me, in full body / interior trim including A/C.
Old Mar 10, 2005 | 02:21 PM
  #55
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
If you have that much horsepower from stock
srdet .
It could be built up.
I srdet usually comes 200-210 hp.
Old Mar 10, 2005 | 02:52 PM
  #56
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
srdet .
Actually your right, it comes rated 205BHP @ 7PSI of boost.
So you got me, I have one mod... Greddy Boost controller.
I turned the boost up to 15PSI exactly... thats how I got those numbers. My AFM is almost maxed too... around 92%; this is not uncommon for SR20DETs... in fact mine is considered a runt around here, there are those going 12.6 and better, but they all have limited slip diff's, I have a one legger.
Old Mar 10, 2005 | 08:00 PM
  #57
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
hehehehe
you should jsut go ahead and beat them silly (in a race)
Old Mar 14, 2005 | 10:38 AM
  #58
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
the car i got my *** kicked by is a 99 gti vr6, now those are light and fast they put out 175hp but damn... he got me(he is a friend) we went 20 miles the whole time doing 125mph now thats kinda too fast for me for that long of time.
Old Mar 14, 2005 | 10:39 AM
  #59
sry. kinda of subject but i figure why not we are talking about light imports.
Old Mar 14, 2005 | 12:34 PM
  #60
stu's Avatar
stu
That's not really a light import though. They are on the heavy side, well, middle to heavy side if you want to talk about Supras and 3000gts.
Old Mar 14, 2005 | 02:53 PM
  #61
yah, i would say that there kinda middle heavy also.
Old Mar 30, 2005 | 02:16 AM
  #62
HorseflyDF's Avatar
Car: 86 Camaro Z28
I just wanted to bring up this point about 3rd gen
I recently purchased.
Im writing this story because most of the guys
here are enthusiasts, and I respect that.
First off I never owned a muscle car .
Im not saying that my car is a muscle car, but I dont have the money to get a decent muscle car from the early 70 and late 60s.
So when I saw this Camaro I said this looks like
a race car and it has an 8 cylinder engine.
Body was clean but not mint and It drove straight,
with no smoke has some torque and a nice V8 rumble
which turned me on big time.
The car for me looks really cool thats about it,
thats why I bought it.
I had no experience with this type of car ever,
I was a little dissapointed at first because I thought the car
should be alot faster.
What I didnt know then and what I know now makes a big difference in how I feel about this car..
I can appreciate it for what it is and the history behind it.
Truth is when I go to the parking lot to get in my Camaro
Im happy, not to be driven my Mini Van.
Old Mar 30, 2005 | 02:57 PM
  #63
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Originally posted by jocww
id be more worried about the old guys
I second that, you don't quite know what the old guys are packing
Old Mar 30, 2005 | 03:08 PM
  #64
stu's Avatar
stu
Plus they are more likely to have money.
Old Mar 30, 2005 | 06:24 PM
  #65
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
....... how I feel about this car..
*sniffle..... *
  #66
freestylzz's Avatar
Car: 1987 Iroc Z28
*tears falling down my face*
*grabbing kleenex and blowing my nose*
*turning down the voilin music playing on the hi-fi*
Man that was soo touching........
One day you too will truley love your camaro more than anything else!
Old Mar 30, 2005 | 07:35 PM
  #67
Tobias05's Avatar
I'm just waiting for someone to argue about that soap mentioned earlier....
Old Mar 31, 2005 | 09:21 AM
  #68
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
yeahim happy to hear 25th said the tpi's are decently fast, you will roll most around you, if you run asti or evo or something then worry, but they are slow cars, and dont worry about it, just dont talk **** to the old guys
Hotrodboba400
Dec 10, 2019 07:07 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
z28joe2
Sep 28, 2015 05:54 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
