what will i run"
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what will i run"
mods in the sig..
new mods are 3.42 10bolt posi over my old 2.77 9bolt posi.
and now a new transmission with extra clutch packs, vette servo, transgo shiftkit, 2400 stall.
how much time will i improve?
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Well, Im not 100% sure but going with the 3.42's will help you ALOT. Not to mention a stall will definately improve any lag in 60ft times you had. I suppose on the juice you'll be around mid 12's or so, give or take a little. you may even hit some low low 12s, its really according to how much those 2.77's hurt you...but the 3.42 was a wise choice indeed.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your biggest ET improvement will come from a better 60'. Those gears should help you do that. You should see a slightly better ET but you will more than likely pick up a few mph on your trap. Both good things.
