Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
WHAT should i have
Old Jun 10, 2005 | 12:09 AM
CoatHangerMan's Avatar
Engine: S52
Transmission: umm gm...
WHAT should i have
Well i broke at half track and ran a 8.0 @93 with a 2.1 60ft.
On my old setup i gained 26 mph from the 1/8th to the 1/4 and on the new setup it should at least be 27 maybe more. Please post your timeslips that are similar i want to know what i would have run as i am changing more stuff and will be even faster.
Old Jun 11, 2005 | 10:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
thats a pretty quick time for the 1/8.. that 60 foot could use some work. should be in the 1.8's i would think and that could drop you into the 7.7's-7.8's at 94-95mph. which i believe is good for mid to high 11's. try asking the guys in the drag racing board....they are pretty good at that stuff
Old Jun 11, 2005 | 11:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
You were prolly on your way to mid 12s on that pass...
Old Jun 12, 2005 | 12:22 AM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Your MPH is high for the 8.0 1/8. Did you break right at,a little before,or a little after the 1/8?If you broke after then I'd say you were on your way to a high 11 or low 12 with that MPH.If you get a better 60' with that MPH you could run mid 7's in the 1/8 and mid 11's in the 1/4.
