Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
What will this combo run?
Old Jun 9, 2005 | 08:29 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
OK, building my motor on the stand, let me know what you think it will run and any help is neccesary and wanted here.
MOTOR:
'72 350 4 bolt main, stock pistons/crank/rods with 65k miles on motor
HEADS:
113 aluminum L98 heads, 2.02/1.6, ported to around 230 lift .400 and 240 at .500....not totally sure, havent gotten them in yet so no flow bench just yet. can take .600 lift
CAM:
CS-292H10 CompCams
Duration at .050 244/244
Adv. Duration 292/292
.501/.501 lift w/1.5 stock rockers
INDUCTION:
Edelbrock Pro-Flo EFI setup EDL-3500
EXHAUST:
Heddman LT's into 2 1/2in dual exhaust dumping before the rear axle
TRANSMISSON:
TH350w/2400 Stall recently rebuilt and has a shift kit
REAREND:
Currently 2.73's....3.42's going in soon.
What do you think? I have everything listed sitting in my garage except the heads and cam, both still on the table. Ill take any and all suggestions here. I have around $1000 to spend on a heads/cam package.
I already have the EFI system and would like to try it out and if I dont like it, then Ill go back to a carb setup with a RPM AirGap and Holley 750DP. However, considering I have the EFI system, its best to try it out first.
GOAL:
mid 12's in the 1/4
350+ HP 350+ torque to the wheels.
Any suggestions on heads and cam is greatly appreciated here. Ive considered AFR's but they are a little too much for me. Ive thought of these as well
World Products Sportsman II Heads WRL-011150-2
64cc angled plugs
200cc intake runners
OR
Dart Iron Eagle DRT-10321112
200CC intake runner
64CC angled plugs
I like the Darts, mainly because I have a good friend that is using a set of Iron Eagles in his 79 Z/28 and its a complete monster, even though its never been at a track or dyno'd once.
what do you all think? The cheaper I spend on heads the better, because it leaves more cash for gears, SFC's, tires, etc....the usual crap and gets everything going alot sooner than expected but Im willing to throw down the cash on some heads. thanks for all your help guys. Predictions are needed of course
Old Jun 9, 2005 | 09:24 AM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
I don't know a lot about heads and cams, but if you have your engine torn apart, I would suggest buying some flat top pistons. They make a world of difference.
Old Jun 9, 2005 | 09:44 AM
Transmission: T5/T5
It wont be torn apart at all. Just swapping the heads and cam not touching the bottom end except for a new oil pan and oil pump..
Old Jun 9, 2005 | 09:45 AM
92RS3.1L's Avatar
Car: 91 Z28
Gotcha.
Old Jun 9, 2005 | 12:35 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
the cam sounds about right for ported L98 heads, but it could stand to be a little bigger if you go with either of the aftermarket heads. For heads i would go with the darts just for the simple fact i've seen them prove them selves time and time again and i know for a fact that they are high quality pieces. Dont get me wrong cause there is nothing wrong with world products i just like dart more.
Old Jun 9, 2005 | 02:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You want to select pistons that meet your compression ratio goals for your motor. Flat tops have nothing speical about other than the fact that they have a certian feautre that you can build a motor around.
Old Jun 9, 2005 | 04:54 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Get the iron eagles and a smaller cam
Old Jun 9, 2005 | 07:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i think when its all tuned right, it should hit 12's easily. that cam and pro flow should make closer to 400hp i would think. plenty for bottom 12's
remember the better flowing the heads are, the more power you can make....generally. dont skip out on heads cuz they can make or break the combo. i personally think that motor could use abit better head...
those vette heads have small chambers--58cc so your compression will be higher. hopefully nothing too high, i dont know whats all in that 72 shortblock. also the vette heads runners are smaller like 160-170cc or something like that.... so flow speed will be fast but that combo might like a bigger runner like 180-200
Old Jun 10, 2005 | 11:41 AM
Transmission: T5/T5
Well I actually want a 58cc chamber because I want a 9.5-10.1 or so CR. I dont want a 9.0 or less because I fear it will hurt me in the long run. I know the stock 882's are 76cc and provide like a 8.6 CR or something close...nothing I want.
Im seriously considering the Darts but Id rather spend a little less on the L98's and get it oging faster. My roommate says get the L98's but I think he fears my little RS with a 350 might get dangerously close to taking down his 383 IROC with those Darts.....never know. Any more suggestions, shoot.
Old Jun 10, 2005 | 12:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i wasnt sure what teh stock compression ratio on 72 motors were so if its high 9's close to 10 with 58 cc then thats what you want.
Old Jun 11, 2005 | 02:35 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
needs more converter. go with at least 3000, possibly 3500. you have more than enough cfm and cam to run mid 12's, 350whp is enough to run into the 11's.
Old Jun 11, 2005 | 10:12 PM
Transmission: T5/T5
Id do that but Im not leaving the 350 Turbo in there. I plan on swapping the tranny out over the winter for a T-56.
The L98's is a no go. So would you recommend 200cc Dart Iron Eagles? anybody?
Old Jun 11, 2005 | 10:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah those iron eagles arent bad......look for the Platinum ones...they flow 10% better out of the box, and have alot of room for porting.
Old Jun 12, 2005 | 09:33 AM
Transmission: T5/T5
Anyone ever used Pro Topline? I was reading some good power output numbers from a mild smallblock build in Chevy High...any experience with their 1800cc or 200cc heads?
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
