Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
400
Old Jul 13, 2006 | 08:51 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
400
I got a 74 model 400 sbc. Its out of a 2500 pickup truck. I don't know much about it. Just curious about how much torque/hp it would make stock?
Until my bud has money to rebuild it, hes just going to clean it up and stick it under the stock 86 computer controlled carb-intake to get it running. I'm thinking 200 rwhp and 300 rwtq.
How would it run against a bolt on l98
New Magnaflow cat
Catback
GUtted box w/K&N's
Slp runners
AFPR
Old Jul 13, 2006 | 09:18 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
400's were pretty gutless stock.
Old Jul 13, 2006 | 09:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably something like 135 HP stock, at the flywheel.
Old Jul 13, 2006 | 11:42 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Stock 70's cars were severely inefficient. It sucked in the car it was in, and with his crappy tune, it'll blow even more. Have fun winning.
Old Jul 23, 2006 | 02:44 PM
vampiroc's Avatar
Car: Z28
yep, might as well run an L03 if you are going to leave the 400 stock. More power, possibly more torque, with less fuel consumption. Considering with the right bolt ons an L98 can run 13s, I'd say you'd be trainlengthed immediately. Not even a holeshot to claim against an L98
Old Jul 23, 2006 | 03:17 PM
Well I found out some more about the motor. he's going to be running a rebuilt, stock type bottom end. 64cc ported heads (L98), Aluminum Dual plane and prob the stock quadrajet with different metering rods. he's running shorty heads with true dual exhaust.
I believe with the compression bump from the small cc heads, better flow from the heads, larger, free flowing exhaust, and getting more air to it, it should be quite different than stock. He's also going to be using posi 3.23 gears, much better than his stock 2.73 open diff.
Old Jul 23, 2006 | 03:26 PM
vampiroc's Avatar
Car: Z28
if he's running a quadrajunk and the same old trashcan cam the stock motor came with you'll still beat him by buses. Basically what you've described to me is a shamble of an engine. He's running L98 heads, which is fine, but so are you, so he has no real advantage other than the porting. He's getting more compression but if he didn't bother to change the cam, more compression with hurt him. Compression is only good if you can feed the engine with enough fuel and air to make the power it can support, and judging by the top end I wouldn't say he's done that. Stock quadraleaks and stock 400 smog cams aren't compression friendly. You'll land on him, hard.
Old Jul 23, 2006 | 10:23 PM
Hes running a different cam also. 228/228 somewhere in the high .49x/.51x lift, can't remeber the exact. 110lsa.
Old Jul 25, 2006 | 08:45 PM
Turns out he orders a holley performer intake, high rise design, holley 650 DP , still not sure about the cam, but its much larger than the stock truck cam.
I though he was going to run the stock intake/carb and stuff, but i heard wrong. he's just going to put them on the motor to make sure it runs, then hell swap over the intake/carb and fine tune it
Old Jul 25, 2006 | 09:27 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Gutless about sums it up.From the factory most were low performance but I have seen some 430hp and 500ftlbs with vortec heads and a xe274.They love to make torque.
Old Jul 26, 2006 | 02:36 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
If he's gonna run l98 heads I hope he knows about the steam holes that have to be drilled? Or he's gonna have problems Don't underestimate a 400 though if it has different heads/cam/intake. I've built a few with with stock compression and they've ran pretty good.
Old Jul 26, 2006 | 08:20 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
a 400 small block oughta make hellified low end torque. Even under the stock LG4 intake and carb. It would be a great launcher, but thats about it.
Old Jul 27, 2006 | 09:51 AM
Its going to be a wierd engine
his lg4 intake and low compression will help bottom end, but the cam and decent heads will want to rev higher. His hp curve is prob going to be flat as hell and max torque will be at 2000rpm. Sounds an awful lot like tpi.
Old Jul 28, 2006 | 04:36 AM
Dano 00TA's Avatar
Engine: LS1/L98
I though he was going with a holley intake? It'll be a decent performer, not a bigblock killer by any stretch but I'd say it'll hold it's own. Gonna be a torque monster and thay's what get's ya going
Old Jul 28, 2006 | 09:47 PM
I would say its going to make about 400 lb ft tq at the crank and 220 crank hp.
It will be fun.
He's just using the stock intake to get teh car running then hes gonna swap the holley intake on.
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
