Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Need some tips on racing.
Old Dec 24, 2006 | 12:12 PM
Benck's Avatar
Car: 1991 Pontiac Firebird
Engine: v8 305 "For now"
Ok first off, i know that the start of the race is critical, and i don't wana be stuck burning out for 5 seconds while the other guy easily makes it to the finish line before I get half way. Whats the best way to start out, btw my cars automatic but I do have 1st and 2nd gear... Any other tips would be apreciated to.
Old Dec 24, 2006 | 12:31 PM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
Every car reacts different. Several different factors decide your launch (driver, tires, tranny, rear gears) I have a manual tranny so i can't help you with the auto part. What i can say is go to the track and test your launch. That's all i do. Every time you change something on the car, it will change the way it acts at the track. You want to find the perfect launch so you don't spin and don't bog down or stall. Also, make sure you heat those tires up good As you can see in my sig, i spin on my launch but hopefully drag radials will help that in the spring.
Old Dec 24, 2006 | 01:45 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
for the launch hold one foot on the brake and hit the gas with the other foot this will make the rpms go up without moving but you can only rev it so high before your tire starts spinning so find the max. now when launching let off the brake and hit the gas as far down as you can go without spinning find that sweet spot.
Old Dec 24, 2006 | 01:55 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
The term "stalling up" is holding the brake and pushing rpm to the point of spinning works well, but I assume you have a open diff, you will get more stall speed and better launch out of a limited slip unit, the gear ratio will also severly effect 60 foot times, drag radials, or even a wider tire will help you, when heating you tires up you do not need to over do it, street radials over heat easily, a 3-4 second aggressive burnout bill do, the track is the best place to try different methods, but your 60 foot will be different on the street, most radials hook up better on the street, and the opposite for "racing" application.
Old Dec 27, 2006 | 08:29 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Stall it up and hope you have good tires!
Old Jan 31, 2007 | 03:48 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
drop it in 1st, hold it in 2nd and dont hit 3rd too early. Its easy to skip 2nd and go straight to third, its important because 2nd is where most of your powers at.
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Night rider327
Sep 25, 2015 04:47 AM
