Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
86 IROC 355 vs. 06 GTO
Old Feb 13, 2007 | 08:17 AM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
Who is the winner? 86 Iroc 355 TFS aluminum heads, 56cc chambers, 175 intake runners, 1.94 1.50 valves, 10.25 to 1 compression, comp cams 479/480 lift 114 ls, 224/230 @.50, 1.5 rockers, edelbrock high flow base, TPIS ported plenum, AS&M runners, 52mm tb, slp airfoil, Hawks ram air boxes, descreened MAF, 24lbs injectors, mac underdrive pulleys, hooker 2055 headers with emmisions tubes cut off, Magnaflow catback, 2500 stall converter, b&M shift kit, 3.73 gears, removed all emmisions and cat converter. LS racing chip and dyno tune.
Against a bone stock automatic 2006 GTO? Who is the winner in the 1/4?
Old Feb 13, 2007 | 09:01 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
[quote=86redIROC]LS racing chip and dyno tune...
What did the engine dyno, then you'll have your answer...
Old Feb 13, 2007 | 09:19 AM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
Going in next month for the dyno tune. Thats why I was asking for guesses before I run it. Jamie at LS racing thinks 12.90's with good traction.
Old Feb 13, 2007 | 09:54 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Depending on traction for both, it'll be a good race. There have been a number of bone stock '05-'06 GTO's run in the 12s. With drag radials, they have gone as far as 12.6 as the only mod. The power is definitely there for both cars.
Should be a good matchup.
Old Feb 13, 2007 | 09:55 AM
86t/a owner's Avatar
Car: 86 t/a
Engine: 383 sbc on nitrous
Transmission: Th350 with trans brake
Axle/Gears: 9in ford
my buddy has a 05 gto ls2 auto has chip and headers with a catback had spinning problems(bad track prep) and ran a 13.2
Old Feb 13, 2007 | 10:11 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
GTO's are pretty quick, low 13's seems about right... i ran one on the street and got pulled pretty good.
Old Feb 13, 2007 | 11:26 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Like the guys above said. It depends on the dyno. My 385 Fastburn, is putting out 423hp 469tq and is running low 12's high 11's. A stock gto aint gonna touch it, now if its highly modded w/ charger im probably 'f'ed
Like the guys above said. It depends on the dyno. My 385 Fastburn, is putting out 423hp 469tq and is running low 12's high 11's. A stock gto aint gonna touch it, now if its highly modded w/ charger im probably 'f'ed, so dyno it and see what you get. Keep me posted I wanna know if you give him a good race.
Old Feb 13, 2007 | 02:23 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Could go either way. GTO's tend to run mid to low 13's usually.
Old Feb 13, 2007 | 03:50 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
I think its gonna come down to launch. You didn't mention what type of rubbers hanging on the back axle, that could make or break you, you've got a good amount of motor, you're lighter, and should hook pretty good with the right setup on the rear. GTO's are quick too, but arn't as easy to hook, from what I've seen. Defintely wanna hear about the outcome
Old Feb 14, 2007 | 07:04 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Dont know if this applies or not, but last year when I was autocrossing I was within 1.5 seconds of a stock 06 GTO. I didnt think that was that bad. My mods are in my sig. The guy was an old man too who said he had lots of experience autoxing.
Old Feb 16, 2007 | 10:29 AM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I think you will win..If the GTO is stock..
It will be a great race though...be sure to get a vid of it
Old Feb 16, 2007 | 12:27 PM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
It will be a drivers race. Be sure to tell the outcome and video it if you can!
Old Mar 9, 2007 | 06:33 PM
1989IROCZ's Avatar
I have an 06 A4 GTO. If its bone stock( with stock tires ) it will have trouble launching. The stock tires just do not stick. I've seen one GTO turn 12.9 completely bone stock but the guy knew how to drive. Low 13's is a good number for most. Just make sure he has no tune. The tune alone will pick up at least 20 hp and get rid of the torque management which really hurts the A4.
Old Mar 11, 2007 | 11:10 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i also went up against an ls2 gto at an auto cross and cosistently had him by 1.5 to 2 secs. granted it was a younger guy drivng, but so am i and my car is bone stock with 150 less hp.
Old Mar 12, 2007 | 05:05 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
If you hook you win.
Old Mar 12, 2007 | 02:17 PM
atc3434's Avatar
Car: 1986 Camaro SC
150hp doesn't make up for the adt'l 500-700lbs the GTO is throwing around, not in auto-x anyways. I would think a stock, well driven third gen would beat a GTO every time in a tight auto-x. A real fast track might be closer as it'll start to favor the powerful cars.
Old Mar 12, 2007 | 03:02 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
[quote=atc3434;3260373]150hp doesn't make up for the adt'l 500-700lbs the GTO is throwing around quote]
Measured Curb wieght for the '04 GTO is 3761 lbs., so unless your F-Bod is stripped, or the '06 model gained a few hunnerd lbs. the difference is more like 200-300 lbs.
http://www.highperformancepontiac.co...ag_strip_test/
Old Mar 12, 2007 | 03:29 PM
atc3434's Avatar
Car: 1986 Camaro SC
[QUOTE=Rayvan;3260403]
Measured curb weight for a 1992 Z28 Couple is 3273lbs... roughly 600lbs different give or take. We all know both cars are going to weight more real world anyways, I think about 500-700lbs difference is still fairly accurate.
http://www.f-body.org/tech/tech.htm#weight3rd
Old Mar 12, 2007 | 04:06 PM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
[quote=atc3434;3260428]
The GTO weight listed in the article *is* real world. IOW, as weighed the day the magazines raced it at the track, so it included fuel.
Your weight listed for the Z28 is (like I said) for a completely stripped. *No options at all* 305 5-speed car, dry weight. IOW, Not very typical at all.
Using the options listed, a lightly optioned (A/C only) 5.7 liter '92 Z28 (race weight) will be closer to 3424lbs. (still with no fuel). A '92 Z/28 with *all* the options (no fuel) is close to 3512 lbs. so the difference is only 248lbs. to 327lbs.
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 11, 2015 03:17 PM
