Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
15.169?
Old Feb 17, 2007 | 01:11 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
15.169?
I am extremely dissapointed with my Z. Last night I ran a 15.169 @95.4mph.... My 60ft was 2.20. but I had an extremely good RT. .240 sec. I did notice that my drivers side rear tire had only 20psi. I don't know what happened. I thought that 350tpis were good for mid-14s at least.
1991 Chevrolet Camaro Z28
350 TPI
Built 700r4
Underdrive Pulleys
Custom Ram air
3" Catback Flowmaster
Throttle Body Bypass
MSD coil
Old Feb 17, 2007 | 06:49 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
95 MPH should be a low-mid 14... If you can get that 60' down to a 1.9 or 2.0 you will probably achieve the ET that goes with that trap speed.
The reaction time has nothing to do with your ET, that's just how long it takes you to hit the pedal and start the timer after the green light drops... If you were competing, you should be shooting for as close to a .500 reaction time without going over, a .240 R/T would be a red light and you'd be disqualified.
Old Feb 17, 2007 | 07:28 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Make sure your black air dam isn't tripping the track's beams at the starting line. I have read a few people have this problem.
Did you leave it in "D" when you raced?
Have you done a full tune-up lately? Some nice aftermarket plug wires would be a good idea. Get some headers!! -Nick.
Old Feb 17, 2007 | 08:16 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Dude my stock 305 TBI with open air element and throttle body spacer ran a 15.6 flat, i always said it was a freak! i could run side by side with my buddies '89 GTA from a dig and a roll
Old Feb 17, 2007 | 09:28 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Make sure your car is tuned. I have seen stock L98 go 14.3 but mid 14s are common.Just want to make sure, but are you sure its not a 305TPI. If your sure its a 350TPI then i would do a tune up(plugs,wires,cap,rotor,check timing etc.) But with a 94mph you should be running faster then 15.1 even if your 60ft was a 2.2.How many miles are on the motor?
Old Feb 17, 2007 | 09:33 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
How did it take until the 5th post in this thread to mention that a .240 reaction time is downright awful? That's a .740 on the old .500 light system. The IHRA (and I believe the NHRA also) went from .500 being a perfect light ona sportsman tree to a .000 being perfect either last year or the year before...can't remember that far back.
Old Feb 17, 2007 | 10:40 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I was unaware of the change, it's been a couple years for me... but I did point out that it was bad... for the other reason thinking that the old system was in place.
Buut.... that doesn't have anything to do with the question at hand... why it wasn't running in the 14's like the trap speed says it should.
Old Feb 19, 2007 | 04:35 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I'm quite aware of the new system, considering I work the starting line at PIR. don't know when it went into effect though. I remember when I first starting working there in July i saw everyone running like .046's and the such and trying to figure out why the hell they weren't disqualified for breaking out. Back on subject, how well was the track prepped? That could make a world of a difference in your ET.
Old Feb 19, 2007 | 07:15 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Read my post in the tpi forums. It's titled mostly stock tpi et's. The guys on there helped me alot!
Old Feb 19, 2007 | 09:20 PM
I know for a fact that it is a 350. I do agree with my 60' time being high. I am pretty sure it is because of the tire pressure in my left rear being low causing me to spin. Also, I just realized that I had it in OD. Does that make a difference? I am putting on my shortys this weekend with new plugs and wires? However, I am going back to the track this wednesday to try to improve on my times. I hope that I do alot better.
Old Feb 19, 2007 | 10:08 PM
DBLTKE's Avatar
Engine: LB9, LB9
Actually lowering your rear tire pressure will gain you more traction off the starting line causing less tire spin and it shouldn't matter whether you were in OD or not, because the 700r4 will not shift into OD at WOT. You did mention that you had tire spin though, maybe you just got on the gas a little to hard off the line? Practice makes perfect.
Old Feb 19, 2007 | 10:37 PM
true. practice does make perfect. Although I thought that on street tires it wasn't good to lower your tire pressure???? I think it was too low though. As I said it is all in trial and error and I will hopefully have a better run on Wed. We will see. I did forget to mention that I had my torque converter locked up. I know that with me trapping at 95 mph, that I should be in the low 14s. I hope that I do better this week.
Old Feb 19, 2007 | 11:21 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
nothing wrong with a 15.1.. all you need to get your mid 14's is TRACTION.. hit a 1.9ish 60ft and there you have it..
Old Feb 20, 2007 | 05:15 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
+1 nearly 96 mph is about right for yur mods with some miles on the car.
Id go with atleast 32 psi in those tires. A good stall headers and tpi port work wil really wake that ol' tpi up.
Old Feb 20, 2007 | 07:20 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
my 89 350 tpi iroc with 2.77 gears ran a 14.4 with a 2.2 60 foot with just full slp exhaust.
Old Feb 20, 2007 | 06:18 PM
My tires are bald so I think that I will have problem getting traction. I know it is capable of getting low 14s. The motor only has about 25000 miles on the rebuild so it is strong. TRACTION TRACTION TRACTION!!! Does anyone have a good launching technique? I hope that tomorrow I atleast break the 14 barrier.
Old Feb 20, 2007 | 06:21 PM
zz4monte's Avatar
I don't know about anyone else but with my pro-built 700r4 I run about .2 tenths faster in the 1/8 mile on average when I shift myself.Thats if I don't shift to late and hit the 6000rpm rev limit on the msd.I don't have a computer though.manual overdrive lockup switch.
Old Feb 20, 2007 | 06:25 PM
zz4monte's Avatar
Wait until you get new tires and a tune up or your probalbly not going to run much faster.I wouldn't run less then 25PSI on street tires anyways unless it was a Drag radial or slick.
Old Feb 20, 2007 | 07:26 PM
5678TA's Avatar
Car: 1984 Trans Am
my friend who is an idiot, ran 15psi on a 16" rim with low-pro tires.. in his intergra of course.. jsut regular street tires.. you could see the rims spinning in the tire.. that bastard still pulled off a 14.9.. as for launching your car, do a little preload at the line.. nothing wild, just brake and give a little gas to bring the rpm's up.. then roll into the throttle as you gain speed.. there is a fine line where you can give so much gas and still have traction.. find it and you will get to 14's.. you want to be at the point right before you lose traction all the way till you can floor the throttle.. thats about all i can advise.. its a trick but if you can get it down, you will be amazed.. lol
Old Feb 20, 2007 | 07:51 PM
Thanks guys. I am gonna try to improve my launch and let some air out of my tires.
Old Feb 20, 2007 | 09:23 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Your mph is way high.
You 60' isn't as good as it could be
track conditions change mph and e.t.'s greatly
mine ran low 15's with a plug wire hanging off
Old Feb 22, 2007 | 05:46 AM
Well I went to the track last night and I didnt do much better. I had three runs and all of them were 15.0**. I do believe that it is traction. consistent 2.1 60' times. We will see after the tune up this weekend........
Old Feb 22, 2007 | 06:41 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
i dont kno man i had just as bad 60 foot and mananged a 14.4 with 2.77 gears and just full exhaust. Id do a tune up and run stock pressure in the tires i ran 25 and i think it greated too much drag by the time i got past 1/8 mile.
Old Feb 22, 2007 | 08:21 AM
MARO-MAN's Avatar
How much better do you expect your 60' times to improve? Your just useing street tires right? You sure the tranny isn't shifting in to OD? What RPM is your tranny shifting at? Did you do a tune up yet and check timing? Is your cat clogged? I can't believe your running slower then my 305 with the same 60' times? You got the MPH and a decent 60' time on street tires, so what the hell?
Old Feb 22, 2007 | 01:17 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Yeah man, I'm running 14.1's at 98 all day with 2.1-2.2 60 foots. My engine is all stock and I have stock exhaust manifolds.
Old Feb 22, 2007 | 08:44 PM
I think it is wierd too. I have no cats. I am so angry. I know I should be running low 14s. I did check my timing. It was advanced to like 13* BTC. I put it back at factory 6* but I think I am gonna put it at like 10*. Im doing plugs and wires this weekend. I go every wednesday so I hope to see an improvement next week. I don't know what else to do....
Old Feb 23, 2007 | 08:23 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I need to go back to the track and see what the headers and exhaust and different gears have done for me.
I ran a 15.2 @ 93mph with 4.10 gears, stock manifolds and a cat.
I now have 3.42's (broke the 4.10's) hooker shorties and a Borla Muffler.
Approx 170K miles are on my motor.
Old Feb 23, 2007 | 11:57 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Hey dude, I just noticed that Your mph dropped a couple since Your last outing. Even though Your et did slightly decrease.... Did you do anything different during Your runs? Was the weather crappier?
Old Feb 24, 2007 | 10:06 AM
Actually, It was a little warmer than the last time i went. I also reset the timing back to 6* btc. It was a 13* btc last time.
