Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
camaro vs ranger
Old Sep 28, 2007 | 01:27 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
camaro vs ranger
I was wondering who you thought would win this race.
I have a 91 camaro with a stock t5 and stock rearend and just got my 350 in. I have...
comp hydro. roller cam and lifters
roller rockers
AFR 180cc heads
Edelbrock High flo tpi system
BBK 58mm throttle body
30lb injectors
9.45:1 compression
I'm not exactly sure what he has done. I know its at least a 302 but maybe a stroker. I was told it was dynoed at 320hp. He has a new trans with a stall and shift kit and a 9'' rearend. ive ridin in it before and it doesnt feel that fast. When i raced him with my 305 tbi from 50-80 he only pulled me a car. Also he raced a trans am with a stock LT1 an got beat pretty bad.
thanks for your help and opinions.
Old Sep 28, 2007 | 02:09 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: camaro vs ranger
probably depnds on the gear ratio he is using. The stock f body rear blows and if his is lower then from stand still you'll loose... but hey there is only one way to find out!!!!!
Old Sep 28, 2007 | 02:58 PM
Demon355's Avatar
Careful with that stock T5 with the 350 +mods.
Old Sep 29, 2007 | 12:20 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
You should have him beat IMO...
Old Sep 30, 2007 | 08:24 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Even if he has done something to get that truck to hook, you should kill him. Obviously it's no slouch on a roll, but from a dig it should be over and done so long as you can hook up.
Old Oct 5, 2007 | 01:21 PM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
I think he has 3.55 gears. I have 3.23
Old Oct 18, 2007 | 02:06 AM
Bs88ta's Avatar
Car: 88 pontiac trans am,79 z28
Engine: 350,350
Transmission: 700r4,th350
i'd imagine the ranger is pretty quick,so go find out how quick
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
