how to make a 305tpi go fast cheap???
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
i want to know how to get a 1986 305TPI iroc go low 14's high 13's in the quarter without NO2 or slicks. would like to be cheap as possible.
thanks.
thanks.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Re: how to make a 305tpi go fast cheap???
Gears, exhaust, DRs, free mods... get everything used and take it to a good track in good air with a good driver.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
assuming its an auto/305 with 3.23 posi gears, it should be a low 15 sec car
youd need some kind of stall converter (around 2800 stall speed) and DRs to get a good launch. thyat should net you mid 14s with no other changes. expect to pay around 700 - 1000 for a decent stall converter and a set of sticky tires
next is going to be full exhaust. Long tube headers, a custom ypipe, and a 3" exhaust system. look to pay between 500 and 750 for a full exhaust setup
finally, do some tuning and free mods. get someone to burn you a custom chip. these will probably set you back a few hundred more
so you could run high 13s with boltons costing around $2000 (if you buy all new parts, used parts will be cheaper)
or you could buy a wet nitrous kit for $500 and call it a day
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
small v8 needs high rpms...so low geared posi, soft rear suspention,remove front anti sway bar,big cam,woked heads,worked intake, used parts are great if you know who you are buying from and what you are buying.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
An '86 IROC TPI is a high 15 second car. It has the flat-tappet peanut cam in it, good for 190 HP. You cant pick up 2 seconds in any car for cheap.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
drive it off a cliff mod, it should pick up plenty of speed on the way down lol
jk
jk
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Fast
Cheap
Reliable
Choose 2. Basically if you want a 305 to be "quick" you will need to do a whole lot. I have a fairly healthy 305 but to get it the previous owner had to do headers, cam, AS&M runners, Edelbrock base, ported plenum, flowmaster 3 inch exhaust. Its putting out 216 horsepower at the wheels. If all that had been done to a 350 then it would be more worthwhile.
Cheap
Reliable
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Fast
Cheap
Reliable
Cheap
Reliable
Engine: 355 TPI
Bristol Dyno in east hartford before they went out of business. Nope i have not taken it to the track ever. I just did a rear end swap that would not really help me at the track anyways lol (3.42s to 3.27s). I just didnt like the rpms on the highway and i dont race really so i gave up a small amount of acceleration for a better cruising rpm. Not to mention i picked up disk brakes in the process.
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
it wouldnt be too expensive unless im giving the 305tpi too much credit im kinda fuzzy on its stats.. but 4.12s work the intake and heads as said a set of 1.6 rockers would help ditch the a/c and get an electric fan if it doesnt already have one a stall costs around 3-400 bucks a cold air can be made cheap via autozone lmao.. should hit 14s with them mods.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I had my '86 LB9 car in the high 13s with no power adders. ALuminum vette heads, small cam, headers, 2800rpm converter. not rocket science. will cost you roughly $2K
Car: 86 IROC
Engine: 383
Fast355
Dec 2, 2016 06:33 PM
