What should I run?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What should I run?
What would you give me as an estimate on the 1/4 mile for my car? Does high 13's seem possible?
305 TPI, bored .030 over, WC-T5, 3.73 Posi, Hooker 2460's with Y-pipe, Flowmaster 3 inch catback w/80series, Comp Cams 212/212 @.050 .444/.444 lift 112 LSA, TPIS Bigmouth Intake and TPIS runners, ported plenum, AFPR, K&N's
Car: 85 Iroc-Z
Re: What should I run?
For tires I have my regular street tires.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
This time of year, at the good tracks we have here in the NE I think you can click off a 13 second pass...even if it's a 13.99999999999
I would really invest a set of Nitto's or BFG's though, especially in this cold weather(summer can't get here fast enough).
Car: 1987 Camaro Z28
Engine: 5.0L LG4 (Going LSX down the road)
Transmission: T-5 (Going T-56 down the road)
1/4 mile calculator. Do a search for one on google.
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
tci website has a very nice calculator....a whole bunch of different calculators.
think it's www.tciauto.com, google though. it's under the technical section.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
It all depends on the tune of the motor. If running the stock prom, stock heads and are trying to compensate for a mismatch in upgrades only with an AFPR, I think that it may not be faster than a stock 305TPI 5 speed.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
its a MAF based system so it can compensate for mods, even a small cam like his, much better than if it was a SD system. even the OBD2 cars can see gains with mild cams and no tuning
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
It had better run 13's with a decent driver You can probably shift that thing around 5400 and go 13.8 at 100mph no problem.
Engine: 305TPI
The MAF system can compensate some. However, the cam the OP is running is not that much bigger than a stock l98 cam from that time, or an LT1 cam for that matter. Not only that, but if running the stock heads, which have smaller exhaust ports, one would want to run a dual pattern cam with higher exhaust lift and larger exhaust duration to compensate for the smaller exhaust port.
Even with the larger intake runners and better flowing base I don't see him making more than 210 hp at the wheels. Also I don't know how much better the 3.73s are making things. The longer runner design of the TPI system, even if it is a higher flowing one than stock, restricts the engine to lower revs. I really doubt that he is making power past 4800 rpm. Higher gear ratios will cause him to spin out of the power band two fast.
A MAF system can compensate some for upgrades but this compensation is no substitute for tuning. Not to mention that his setup seems a little mismatched. Thus, mid 14s is about right as far as ETs are concerned.
Engine: 305TPI
Engine: Vortec 5.7L
Transmission: WC-T5
Yes,
Engine: 305TPI
Stock 305 TPIs make peak power at 4400 rpm. This is with the stock TPI and a 207* int, 213* duration cam. With his intake duration at 212, 5* more, I doubt that his power curve has shifted more than 4-500 rpm from that. Intake and exhaust will help some, but I don't know that it is going to be all that much.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Yes,
LB9/5speed cars came with 3.45s stock... so 3.73s wouldnt do anything dramatic like make it rev out of its powerband too quickly. with my old IROC, the stock gears would cause me to go thru the traps at 4300rpms. with 3.73s, it would only increase rpms to about 4700rpms, right were a stock style intake manifold TPI needs to be at the finish line. they would also make the car leave the line slightly harder, taking advantage of the TPIs down low torque and getting better 60fts... ultimately leading to better E/Ts than mid 14s
obviously his cam isnt quite right for his setup, but to say it will see no gain or even lose power is just not true. tuning will always optimize things, but for small mods like the OPs, its not 100% necessary to see a gain from his work
of course all this is just in theory, as a real drag racing session would let us know exactly what the car is capable of. it will also come down to the drivers ability, weather, and track prep
Engine: Vortec 5.7L
Transmission: WC-T5
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
you dont want to shift everytime above peak power, just go through the traps slightly above peak power
Engine: 305TPI
It is a matter of preference of either standing on the conservative side of these estimates, or the optimistic side, prior to finding out on the track.
Car: 85 Iroc-Z
For what reason do you think that my cam isn't suited for my application? What size cam would have been a better choice? Thanks for the responses so far.
Engine: 305TPI
If you are running the stock heads (416 cast number with perimeter bolt valve covers) the exhaust ports are smaller than the intake ports. They flow about 180 - 190 CFM on the intake side at the .444" valve lift that you have and only about 105 - 110 CFM on the exhaust side due to the smaller exhaust port. In order to allow for the exhaust gasses to escape more efficiently, a split pattern cam is more desirable, where the valve lift and duration on the exhaust side is higher than it is on the intake side. This will allow more time for the exhaust gasses to escape and thus help with better cylinder filling.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
