Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
83 Camaro Vs. 99 Civic
Old Aug 26, 2010 | 01:13 PM
Torisuna's Avatar
Ok I have been all over the net looking for some where to ask this and this place seems like the best so far. So heres the details. I have a 305 83 camaro with a racing cam, hi performance intake manifold, holley 850 double pumper carb with headers, and a 3500 hole shot converter*oh and 80-100hp nos kit for it*. Some other minor things but that covers the costly things I have done.
Now the Civic is a 99 and has a turbo on it that runs 15lbs all the time. I dont know much about Civics or Hondas in general but I just want to know if I could beat it or have a chance, or if people could give me advice on what I need to win against it. So let me know please.
Old Aug 26, 2010 | 02:06 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 83 Camaro Vs. 99 Civic
Are you going heads up or is he giving you a couple?
Good luck
Old Aug 26, 2010 | 02:11 PM
Project-RS's Avatar
that carb is way to big for a pretty much stock 305. i have a decent built 355 and 650 is whats recommended for that. in my opinion, i dont think you have a chance against a turbod honda. even if its the base model 4 cyl. you might have the torque off the start, but as soon as he makes boost hes going to be ahead. hope im wrong on this because i hate to see a fellow 3rd gen lose. good luck
Old Aug 26, 2010 | 02:18 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
That carb is way too big for a 305 unless you are making power at 8000RPM. I'm not sure what a racing camshaft is either. Do you know what grind it is?
Old Aug 26, 2010 | 06:03 PM
Torisuna's Avatar
Well we pulled the camaro in to the garage I still have yet to finalize everything. What carb do you guys suggest be the best for the 305? Im just now getting in to engine stuff. I use to only be interior work and wiring. Im going by this people have tried helping me and telling me to get. I need some suggestions.
To answer some questions.
@Wadebryant- He said he would give me 2 cars on a 30 roll but he wont race me from trans stop because the converter.
@Project-RS- Can you give me any advice or share some pointers with me by chance? I mean I really need help making this a good car its just me doing the whole thing and I dont want to drop everything back in and have to redo the process because I did it horribly wrong. any help is welcome.
@Doom86- Grind? Is that something to do with the lift or ratio of something. Imma lost when you start talking expert on me sorry. Like I said I use to do custom interior and wiring for cars not so big on much else.
any feed back is welcome thanks!
Old Aug 26, 2010 | 08:08 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Real racing is heads up. Wether that be from a stop or a roll, everyone leaves at the same time. If he really thinks he'll be 2 cars ahead of you by 30, then taking you from a stop shouldnt be hard. 30 is still first gear.
Grind is your cam specs. You say you have a racing cam but that means nothing. We are looking for the actuall specs on your cam. For instance, I have a solid roller cam with 236 degrees duration at .050" with .550 lift on a 110 LSA. If you have your cam card still it will give you numbers like this, although probably smaller. Also, what intake?
On a 305 with what is probably a mild cam, I wouldnt go bigger than a 600 cfm carb. I'm pushing near 500 horse and only have a 650.
In the end though, I think he will take you. I use to have a 96 firebird V6 which didnt have much less power than you (actually it may have been more). I got wooped by some kid eating cheetos in his turbo CRX.
Old Aug 27, 2010 | 06:51 AM
Torisuna's Avatar
Oh I see yeah I didnt get a cam card this 305 is from a buddy and he told me some things on it and I bought some things for it as well. He just said it was a hi performance racing cam brand. I probably will breaking the 305 down when I get the tranny back from being benched. Just to make sure of things. But as for intake im sure its still stock, nothing out of the ordinary.
Old Aug 28, 2010 | 04:49 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Torisuna, do you have any idea what the civic runs at the track? That would be really helpful to determine what you need to do to your car. He could be a 14 second car or a 12 second one.
Old Aug 29, 2010 | 08:37 AM
Torisuna's Avatar
hes easily 12 seconds because the turbo makes him spin to much.
Old Aug 29, 2010 | 05:48 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
So what your saying is he could be faster if he had traction? Did he show you a timeslip? If he is in the 12s you might as well save your breath. Your 305 even with a 100 shot most likely wont keep up.
Old Sep 26, 2010 | 01:56 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
15lbs of boost? i hope his engine isn't stock or he'll be replacing it soon
Old Sep 26, 2010 | 11:50 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
My best friend of 10 years owns a 97 Honda civic with a ls b18 swap as his daily driver. His car has forged eagle rods, forged pistons, new bearings, milled heads and a decked block, type r oil pump, stage 2 cams and various other odds and ends. I helped him build it over a course of a year with a 5000 dollar budget. The car has a hybrid T3/T4 turbo, Log manifold with a tial waste-gate set at 18lbs, Its inter-cooled with approx 2lbs lost through the inter-cooler so its running about 16lbs of boost DD. The civic has very minor transmission work as well as a stage 4 unsprung clutch. It was just dyno-d on a dyno jet over the summer making just over 380 whp. At the track his best run was a 12.89 with slicks. Those cars are fast. If his car truly is a 12 second car there is no way you will win with what you have.
What would help is the type of motor in the car. The 99 civics came stock with a d16. The si's came stock with the b16. I highly doubt the car is stock because those motors wont last anything past 12psi with a stock footprint.
If its a d16 with 15lbs of boost it could be putting out close to 300hp. If its a b16-b18 it could be putting out safely anywhere from 350-450hp and up if it has a tremendous amount of work.
Old Sep 26, 2010 | 01:30 PM
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
Off subect I'm sorry but hey project rs do u have a youtube channel of your car with either the xe274 or the 292 magnum I swear I was lookin at cams on youtube and I saw ur car.... forget that damn honda tell him heads up or nothing then stomp the peddle and hope for the best
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
