85 iroc carb 350 vs 87 iroc stock tpi
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
Ok I bought my iroc from my cousin who is also the owner of the 87 iroc here's the deal he clames his 87 is faster than the 85
The 85 has
350 bored.30
Stock crank flat top pistons
Rhs pro action heads fitted with comp springs pushrods rocker arms and guideplates
Comp cams 292 magnum
Edelbrock performer intake
Holley 750cfm vacuum secondary
Holley mechanical fuel pump
Stock t5 with stage 2 zoom clutch
373 rear end
His 87 has
Free mods
35k original miles
Flowmaster exhaust with heddman headers other than that its stock
He claims he can beat me I honestly see no way in hell he's faster that he's just talkin out of his *** just posting here to make sure I have the win locked in
The 85 has
350 bored.30
373 rear end
His 87 has
Free mods
35k original miles
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: 85 iroc carb 350 vs 87 iroc stock tpi
U mm not a chance he will win unless this is your first time driving a manual. You have him at every angle. You "should" be making at least 200hp more than him. Make sure your tires hook off the line there's no need to push it against this kid. Its silly a question to even ask.
Just curious why you have vacuum secondary's your motor mated with a T-5. I have always found that mechanical secondary's perform much better with manual transmissions especially on build motors.
Also how is your T-5 holding up. Im doing some head work next season and I wasn't sure these things could handle much more than 350-400ftlbs of tq without breaking down. Even though the stock limit is rated at 300ft/lbs.
Car: 1985 iroc z
Transmission: t-5
Th vacuum secondary was free so... the tranny is holding good so far other than the clutch burning out... but that was with stock ported heads and a smaller cam so ill see how it holds up to what I have now... it only has to last me another year or so I'm planning next winter to do either an ls swap or a 383 t56 combo... most likely the 383 cause I'm not that knowledgable yet I feel way more comfortable with old sbc's....
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Carb will kill, even bone stock, carb swap alone will murder the TPI.
My BONE STOCK 150xxx mile L98 with a carb conversion and headers went 13.87 at 101.xx MPH.
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Wow! Thats a huge improvement in time over the TPI. What manifold and carb combo did you have? And what gears? Stick or auto? I may have to consider this for my brother IROC-Z that he just wants to throw a mild 350 in for now.
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I don't get it. If your cousin owned both vehicles, shouldn't he know which car is faster??
Car: 1985 iroc z
Transmission: t-5
he owned both when mine had stock ported heads and a lunati 00016 cam which is somewhere around 240 duration and .448 of lift I "I could be off on those numbers" swapped the heads and cam to the rhs pro action heads and comp magnum 292 which is 292 duration and .501 lift... that and the car wasn't tuned right when I got it from him it sounded and looked nice but it was running WAY too rich and the idle was all screwed up. But I think the biggest factor in him thinking his car is faster is just mental cause we lived 8 blocks away from eachother ou whole life and the original owner of his iroc lived right in between us and my cousin dated the owners daughter I was friends with the owners son so we had both been around the car a lot we both thought that camaro was the fastest car in the world growin up and I don't think he wants to come back to reality and admit its just a stock camaro I mean the car is mint in every way he just has it all built up in his head that he could smoke me...he got that car for about the best deal I've ever seen to the owner knew we both wanted it really bad and he was getting ready to move out of state and was selling his cars he called both of us a few days before he moved and said the first one t get here with a 1000 bucks can have it.. obviously he beat me.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Was with the Performer RPM knock off professional products and a holley 750(way too big or a stock L98), Stock T5 trans and a 4.10 gear, launched like a baby with only a 1.87 60 foot in fear the rear would break(it did on the next attempt at a pass).
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
