What do you think of my build?
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
Block: 10067353 Brand New Goodwrench 350 Engine
Pistons: .020 like stock pistons
Cam: PRO-2000 195°- 210° duration at .050”
Intake: Holley Street dominator
Heads: casting #33417369, 1.94" Intake valve, 1.50" Exhaust Valve, 76cc Combustion Chamber.
Exhaust Manifolds: Stock
Rearend: 2.??
Transmission:TH350 fresh rebuild, with a B&M shift kit.
Carb: Edelbrock 4bbl
Stock it says the engine should have 250 hp and 350 lb of torque. I also did an A/C delete.
I hope I have increased the performance by a little but I'm worried about the low compression with the heads.
Rearend: 2.??
Car: 84 trans am
Re: What do you think of my build?
Just a mild street build. Not a drag car by any means but just some get up and go. I will eventually build a new block that is pure power but this is just to get it running for now.
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
It should be decent for a mild street build. Some weak links could be the restrictions of the heads and stock manifolds. I dont think its a big issue on a street car but many around here seem to not like Edlebrock carbs. A gear change would probably be a very good upgrade as well.
Car: 84 trans am
Yeah I figured those were weak points. The rearend will be changed over the summer to a 3.73 or higher. I'm estimating about 300hp, is that a fair estimate?
Engine: 350 Vortec
Im no expert but that seems optimistic with stock manifolds, and that cam seems pretty small. You also dont mention the size of the carb?
Car: 84 trans am
