Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How fast should this go in the 1/4
Old May 16, 2001 | 12:32 PM
KW87GTA's Avatar
I have recently brought this car back to life. It used to run great see the times at the bottom of the signature. It was sitting for two years, and had some problems that are now fixed. I am a little curious, because with my new GTECH I have only been able to get a best 13.93 at 102.6 with all the mods below. This was with no spin in first because of slowly easing into the throttle. However, when it shifts into second the tires break for a good half second. I thought the car should be even faster than it was because now I have gutted the cat and dropped out all the emissions. I was expecting around 13 seconds, but this run was really poor. I suppose it could do with where I am shifting, maybe to early or too late, but I am just wondering what you all think it should run. Thanks.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old May 20, 2001 | 09:34 PM
idrag2's Avatar
Moved to Drag Racing board
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Vincent135
Sep 28, 2015 10:50 PM
