Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How to launch an IROC-Z with stock suspension and 2.77 gears??
Old Jul 8, 2001 | 01:33 AM
Like a ROC 89's Avatar
It's an '89 Iroc 350ci with a 700R4 trans. Running on the stock suspension and 2.77:1 ratio in the 9-bolt rear. I have heard to bring the RPM's up to about 1000 and just nail it. But doing that I just spin like crazy and get wheel hop. I tried this at the track last year and was pulling 2.2? to 2.3? 60ft times on street Goodyear Eagle GSC-Z rated tires with real good tread. It has only basic bolt ons like headers and catback, ported plenum, and some ignition work, so its stock. I was running in 90 degree heat and pulled a best of 14.2 at 99.4MPH. I did notice that I was running out of RPM's at the end of the 1/4 and had to pull out before hitting redline on every run. That can NOT be right with 2.77 gears!!!Is it possible that I am spinning to much and losing most if not all of 1st gear? How should I launch? I was thinking bring the RPM's up to 1000 and slowly bring the gas to the floor till it gets going and then just hit it the rest of the way.... How does everyone here launch with an auto????
Thanks!!!
Old Jul 8, 2001 | 02:36 AM
Ski89Z28's Avatar
I have the same kind of car you have and with stock suspension with the exception of a panhard bar.
I race at the track by just idling at the line and hitting the gas pedal all the way as fast as I can. With this way I get 60' times between 2.01 and 2.12 with no wheel hop.
I also have 2.77 gears and buy the end of the track 1/4 mile I still have plenty of rpms left at the end. I am nowhere near the red line, I think may be 4000 rpms.
I also think that you don't have 2.77 gears if your hitting the redline at the finish line.
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Member of JFA Crew
Old Jul 8, 2001 | 03:22 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
<font face="Verdana, Arial" size="2">Originally posted by Like a ROC 89:
It has only basic bolt ons like headers and catback, ported plenum, and some ignition work, so its stock.</font>
If u have those things its not stock!! Stock means it is the way it came when bought, u could say its almost near stock but not stock. With the right conditions, u are going to get better than stock times with those. Just wanted to say that.
89 RS
Looking For:
87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited July 08, 2001).]
Old Jul 8, 2001 | 11:52 AM
IROC5.7TPI's Avatar
You said you were running out of RPMs....
Your trans may not be upshifting the 2-3 and you're crossing the line in 2nd.
Back to the topic....
Launch at 900-1100 RPM, but only leave at 1/2 throttle until the car gets moving, then flat peddle it. You will cut a better 60ft. and probably get a 14.0 at the same time.
Then again....you could always buy some real tires that will hook.
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jul 8, 2001 | 05:04 PM
Ski89Z28:
I am 100% sure I have 2.77 gears. I did the 70MPH in D and it was spinning at about 2800RPM's. I also checked the RPO codes and it said it was a 2.77 rear. I also had the single cat exhaust.
IROCZTWENTYGR8: Ok its not 100% stock but I have only basic bolt ons so its very near stock.
IROC5.7TPI
The trans is upshifting into 3rd. All the shifts are firm and there is NO slipping. I will try a different method of launching. I was thinking more of 13.8-14.0 with that MPH.
Anyone else have a good way of launching? Could it be possible that I am spinning too much and losing all of first gear? Would that make sense???
Thanks!!!
[This message has been edited by Like a ROC 89 (edited July 08, 2001).]
Old Jul 8, 2001 | 05:05 PM
Administrator
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old Jul 10, 2001 | 01:40 PM
Anyone else wanna give me some tips????
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Jun 22, 2021 08:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Aug 26, 2015 08:17 AM
