Goodyear GS-C owners, tire pressure for spirited street driving?
Car: 92RS
Engine: 357
I want them to wear well but I'm trying to get less sidewall roll.Right now I'm at 38 fr and 36 rear.They are rated at 44 lbs max .These are SLP take offs from new 4th gens, does any one know what they recomend for tire pressure on new camaros?What are you guys running for pressure on the street?
Thanks,Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
Edelbrock TBI performer manifold
180 thermostat
Hooker headers
3"cat back
Zexel Torsen posi with 3.42 gears
Thanks,Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
I run 35lbs in all 4 on my T/A
2000 NHRA Edition T/A
Pewter Metallic
A4 3.23 Gear w/GSC's
Whisper lid, MAF Ends, Ram Air Kit, Exhaust C/O
Best 60ft:1.94
1/8th:8.381@86.03
1/4:12.963@108.44
1989 IROC-Z 5.7
Duel Cats
Auto w/3.24 gears
Pewter Metallic
Best 60ft:1.94
1/8th:8.381@86.03
1/4:12.963@108.44
1989 IROC-Z 5.7
Duel Cats
Auto w/3.24 gears
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I would recommend going with the pressure suggested on your door jamb and if you want extra traction drop down to 32 PSI, it is probably safer not to go too low (less than 25 PSI), and going too high may cause funny wear patterns...
To those people that run ridiculously high pressures... where did you learn this? Bad habits bad bad bad...
BTW I run 35 Lbs all around on my Eagle GA's
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear Eagle GA's, AIWA bargain basement (from Sears of course) CD player, Fuzzy dice, Eight-ball shift ****
Check out my ride here $1600!! Bye Bye on board computer!
[This message has been edited by ChillPhatCat (edited September 20, 2001).]
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i odnt have any numbers, but i have a friend with a 5.0 that has GS-Cs, and he ran them with so little air that they almost looked as if they were flat. i mean, not bad, but it was definitely noticeable by looking at them.
and by the way...his car HOOKED.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1992rs/ss
16
Jan 28, 2016 09:58 PM
92camaroJoe
Aug 13, 2015 06:07 AM
