Grand Am vs Monte SS
Car: 1986 IROC-Z
Engine: 5.0 TPI
I know its not thirdgen, but opinions would be apprecited.
Simple question. I got a 2000 Grand Am SE2, 3.4 v6. Friend has 2001 Monte SS, 3.8 v6 (i'm prety sure the SS has the 3.8) Both cars bone stock. Any outcome predictions?
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
Coming soon: paint job, new interior, MSD-6A, MSD GM Blaster Coil, MSD 8mm Helicore wires, Catco Hi-Flo cat, Dynomax Cat-Back, K&N Filters
Daily driver:
2000 Pontiac Grand Am SE2
www.geocities.com/camman86
Daily driver:
Car: 1986 IROC-Z
Engine: 5.0 TPI
<font face="Verdana, Arial" size="2">Originally posted by mss:
you are going to get pulled , losing isnt always a bad thing though , just make your car faster
</font>
</font>
Daily driver:
Car: 1986 IROC-Z
Engine: 5.0 TPI
<font face="Verdana, Arial" size="2">Originally posted by 85transamtpi:
I would say the monte. They are pretty quick. I havent seen any 1/4 times for the Grand Am, but I know the monte runs a mid 15. Give it a shot and let us know!
peace</font>
peace</font>
Daily driver:
The Grand Am GT also has better gearing than the SE, which is probably where most of the performance difference is.
It's a joke that Pontiac tags the GT as having a high output motor when it's only 5hp stronger than its SE version. To add to this, the 3400's used in the Monte's and Impalla's as base motors are rated 5hp higher than the supposed high output motor in the GA GT, and the torque is the same.
Also, the 15.43 is quick for a stock GT, which normally runs high 15's in the 1/4 mile. The SE is probably a low 16's car. But I still say race the SS, because you never know what can happen.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
If you compare 0-60s, the cars are identical (7.8 seconds). I've driven 3.4 GAs/Aleros and 3.8 GPs/Intrigues...I gotta say they feel almost identical in the way they pull.
Only one way to find out right???
Jason E
'89 Camaro RS
-Medium Grey Metallic
-2.8, A4, T-tops, 95k miles
-Hypertech chip, Accel 8.8MM wires and coil
-K&Ns with gutted airbox
-Alpine 60x4 with Boston 746s and RX97s
'97 Z28
-30th Anniversary package (white with orange stripes)
-LT1, M6, t-tops, 46k miles
-Xtant 403a 50x4 + 300x1 powering a 10" Eclipse Aluminum in a JL Stealth box, Boston RM6 fronts, Monsoon rears (temporary!!), Eclipse 5341R CD, All Monster's goodies...
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Jason E
'89 Camaro RS
'97 Z28
Long Live #3...
the 3.8 will win i'm pretty sure...
1998 Ford Ranger 3.0 Cold air intake and flowmaster exhaust.
FOR SALE: 1995 Red T-Top Camaro...Got a ticket, now my insurance is too high...
1989 5.0 RS
1989 5.0 RS
Ok the straight ****
Monte SS
3.8L
200hp @ 5200
225 lb.-ft @ 4000
3400lbs
Grand Am SE2
3.4L
170hp @ 4800
195 lb.-ft @ 4000
3100lbs
Grand am has better gears, I would say it is very close you got almost 300lbs on him but he has 30 in both Trq and HP, so maybe him by half a car.
1989 Trans Am GTA
Monte SS
3.8L
200hp @ 5200
225 lb.-ft @ 4000
3400lbs
Grand Am SE2
3.4L
170hp @ 4800
195 lb.-ft @ 4000
3100lbs
1989 Trans Am GTA
Not to be argumentive, but the SS has a 3.29 final drive ratio(axle ratio), as does the Grand Am GT. Last I checked, the SE had a 3.05 ratio. The Grand Am does have smaller diameter tires, though, which helps acceleration.
I build the 2003 Monte's in Oshawa, Ontario and you will not beat a Monte SS with a Grand Am GT, I'd put money on it.
On the upcoming 2003 models we are putting a new revised supercharger on the 3.8L in the Monte SS's. Boost will be higher than the Grand Prix GTP's version, and the motor compartment (my area) is getting a lot of extra reinforcements. The Monte's also use an aluminum engine cradle to reduce weight. The 2003 Monte will run mid to low 14's.
I'd say the Monte because I raced a Monte and a Grand Am and at least the Monte stayed close behind....
Trevor
87 Z28 - LG4 - 305
Hedman Headers, Y-Pipe, Dynomax Exhaust, K&N Open Air Filter
2 - 8" MTX Black Golds, Clarion 6x9's, Boston 4x6's, Sony Deck
http://immortaltk.tripod.com/z.html
90 Plymouth Laser (Beater)
"If that's your beater I'm paying you too f!cking much" - My boss
Trevor
87 Z28 - LG4 - 305
88SS6SPEED
Nov 11, 2015 07:05 AM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
