advice for track...launching
I hear guys always say stock 305's have no trouble with wheel spin...I do however, i made a huge cloud of smoke today with out touching the brakes. My tires are worn out, REAL bad... but i'm not getting new ones on till next spring, b/c my snow tires are going on real soon...
Anyways, i've only raced on the street, with traction problems, but tommorow i'm going to the track. Can you guys give me tips for launching and everything else, my car is in the sig, and i have bald tires...
THANKS,
mike
btw, what should i be running?
1989 G92 Iroc 305 5spd 3.45 posi
mods: airfoil, MAF screens, flowmaster 80's, K&N's, TES headers, Catco hi flow cats (dual of course).
Other:
Tints, Eclipse CD8051 HU, Nakamichi pa504 (50x4 watts), Polk 4x6's, Polk 6x9's, Xtant 1001x amp (1000 watts), 2 xtant X-series 12 inch subs= people know i'm comin' a block away
Soon= ram air, ported intake, cam, ignition
THANKS,
mike
Other:
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
14.8 @ 93 2.3 60 ft
just try to launch at a little above idle like 1500-2000 rpm's
i don't see why people say 305's don't have problems with traction i get a good bark in 3rd with my 3.08 gears
Andrew
Andrew Peery
1987 IROC, 305 TPI, T5
Hooker Competition Ceramic Coated Headers, Custom y-pipe, Cutout, Flowmaster, Ported Plenum
All smog equipment gone and no cat
before headers
192hp and 265tq
15.20 @ 92.5 mph 2.4 60ft
After Headers
14.480 @ 95.01mph 2.194 60ft
With y-pipe
14.43 @ 96
2.16 60ft
with cut-out
14.11 @ 97.7 2.17 60ft
Andrew
Andrew Peery
before headers
192hp and 265tq
After Headers
With y-pipe
14.43 @ 96
2.16 60ft
with cut-out
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
With good tires I launch at about 2200-2500 rpms. I come off the clutch quickly and then quickly roll into the throttle.
You should probably lower your rpms from mine a few hundred due to your tires.
I won't be doing this till next spring now, it's broken
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050"
HoosierinWA
Oct 7, 2015 10:15 AM
