Whats the fastest you've ever gone in your 3rd gen?
I've hit 100 once..felt ok..but I wont be hitting that again in my camaro
Whats the fastest you've gone on the highway with your 3rd gen?
1988 Sport Coupe 305 TBI
K&N
Flowmaster 80
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AIM: RyanNH84
K&N
Flowmaster 80
Daily driver:
AIM: RyanNH84
Car: 99 Formula
Axle/Gears: 342
You might want want to check the archives on this one, it came up a month or so ago or the Tech/Gen Engine board, there were numerous posts. I've had mine up to 120mph, but considering there is something always going wrong with my car, I was kind of worried. This was when I was racing an Altima to a place to get something to eat.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
was in a friends 86 firebird with the 305 auto
I was in overdrive pulling 4500 rpms
the speedo only went up to 85 though
fbut when you are doing 70 the tach reads 2000rpms or so
so I was moving
ICQ 4116192
AIM RXspeed87
Got rotary?
header, intake, ported TB
soon to have 4.30 rear, ported intake(just need to intall)new catback,ported motor and lighter triangle
so I was moving
ICQ 4116192
AIM RXspeed87
Got rotary?
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I did a buck twenty with change(120+mph). The fellow in a brand new Caddie, whom I raced, must have felt humiliated but I didn't feel too good taking a 11-year-old car to such a speed.
There were all kinds of noises.
3rdGens were not meant for those kinds of numbers,IMHO. An IROC or a Trans-Am are not a Supercars.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners w/Edlebrock Base, March Power/Amp Pulleys, Richmond 4.10 gears,265/50/16 BFGoodrich rear tires.
1990 Formula
Car: 1992 Z28 1LE
140mph, with a bit more of 4th gear to go, and all of 5th... 3.23 gears. I wanted to go faster, but I had my window about 1/2 way down, and the noise turbulence was deafening, and I was nearing a spot that's somewhat notorious for cops
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
I buried the needle in my 145mph speedo while racing a vette on the highway. Things started getting pretty blurry at that speed..hehe..
"Turn a 12 second dream into a 10 second reality"
406 SB coming soon..
About 130
The Sumbitch is Broken
82 Camaro:350, Erson cam, ported heads,Comp Cams 1.6:1 rocker arms, Edelbrock Performer RPM intake, Holley 600cfm,
TH350 tranny with 2500 stall, Eibach Pro Kit, SLP 1 3/4" headers with 3" Flowmaster exhaust
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Well, according to my tach and the MPH equation on this site w/ my gears, tranny, tire height, etc.= 126MPH. My speedo is off b/c of a recent gear change. That was 5600 rpm in 3rd w/ a 700R4 and 3.42, got there pretty damn quick. I can't wait for the new tranny and WOT shifts into OD
BTW, the car felt very smooth and solid, not scary at all.
89 IROC-SuperRammed 355 w/ AFR 190's and LPE 219/219 cam-http://www.geocities.com/buckeyeroc
[This message has been edited by BuckeyeROC (edited October 26, 2001).]
115...
when i first got my license, before my first ticket, fun **** !!!
if i get another ticket tho the judge says my license is gone, i got pulled over last weekend, but thank *** for the pba card...
-drive careful guys-
mike
mike
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
145 then i stopped, i was a bit worried of getting caught, i'm hoping over 155-160 when i do my turbo 3.8 for spring
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
I had mine to 148 mph with plenty of pedal left, but my bad struts kicked in and the front end was bouncing a little. Otherwise she did pretty good as far as handling and noise.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
I slammed the rev limiter at 145 with the t-tops off. That was with a 350 and t-5.
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Cody "cyZ28" Young
I was racing a turbo porsche and he stayed at 135 mph and I pushed my Iroc to over 145mph. The car handled well and the highway was clear cause an accident behind us had all the traffic tied up.
But never again, things ahead of you come way too fast! You really need a clear road to go these speeds.
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Somewhere between 125-130 heading into "The Kink" here http://www.fastone.com/TMap99.pdf
I was around 5,000 rpms in third. The car is a 5.7TPI, 700R4 with 2.77 rear. There was quite a bit more speed left (4th gear) but I never would have made the turn...
I go back to this track on Friday.
[This message has been edited by KeithO (edited October 27, 2001).]
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
89 RS 2.8 12/3?? Unhooked something in dash, cable speedo still worked must have been vss to ecm ?? 115 speedo pegged out and still pulling with 255/60's on rear so that tricked it some too, 94 Z28 153? speedo ended at 150 went a little past last mark.. *mental note: buy bigger speedometer*
Did around 145 in my old 84 Berlinetta...well, with a fresh 350 anyways. Was coming up to a weird spot in the road, goes downhill, straight for about 10 feet, goes downhill again, quickly, and the car's front tires weren't touching the ground anymore, completely lost steering feel...decided to back off it then...
Car: 1993 Ford Mustang
Engine: 5.0L
My speedo stops at 85 mph, but it does 106 through the 1/4. On the dyno, I hit 130 in 3rd before it hit the rev limiter. Not a third gen. but I felt left out
1989 Mustang LX 5.0 Coupe
13.34@106.7 - needs more gear and converter
1992 Mustang LX 5.0 Convertible
14.23 @ 95.something - 100% bone stock motor - it's been a while since I've ran this one
1993 LX 2.3L Hatchback - "The Ride to VCU"
Moderator Stangtec.com, SN95.com
Amelia and Nic's Twin Terrors
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Ive buried the needle in the Iroc. the speedo goes to 240kmh.(I'm in Canada) and I brought the needle almost down to the little odometer button in the middle of the speedo. I'm guessing about 260+kmh. this was my 305TPI and T5. Though I was right in the tachs red zone, maybe thats why the engine puffs blue now. Oh well engines coming out anyways. Oh yeah, and the car handled perfect, now if only the windnoise would go away.
Dave
Dave
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Only had my car a few months. Did 100, smooth as a babys butt.
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC In Readers Rides
My IROC
[This message has been edited by IROCThe5.7L (edited October 27, 2001).]
1988 Jet Black IROC
5.7L W/ 64000 miles
Flowmaster Exhaust
Fully Loaded
My IROC
<font face="Verdana, Arial" size="2">Originally posted by IROCThe5.7L...
...smooth as a baby's butt."</font>
PEDOPHILE!
lol j/k
The fastest I've had my Formula on the interstate is probably 95 or so. No reason to max it out though, I bet I could get it to go faster by driving it off a cliff!
-Todd-
1989 Formula WS6
Recently re-converted back to bone-stock for economy.
-L03, Auto, 2.73, etc.
Best Run(formerly modified): 14.1 @ 97 mph.
Recent Run(Stock): 16.1 @ 83 mph.
1988 Mustang GT
-T-tops, E-303 Cam/1.6 rollers, 3.73 gears, Auto, 4" cowl,
fiberglass hatch, Hooker headers into Flowmaster 40s, and much more.
Best run: 13.87 @ 98 mph.
1991 Mercury Topaz
-2.3 HSC I4, Auto, winter beater.
1986 Buick Regal
-Drag car project for my built Olds 403 V8.
137 it coast me two nights in jail 30 suspention on my drivers licens and almost 1000 dollers in lyer fees and cort charges. Ill never do that again I ride hard at the track now. For got to say I have an 87 gta with the 145 speedo and it was baried at that speed you can almost bet your speedo is off at least 10+
[This message has been edited by Earl 87gta (edited October 27, 2001).]
I got mine up to 130 once but that was when i was young and stupid. Now the fastest I go is 75 down the freeway.
'89 firebird formula tpi
custom cold air,gutted maf(just screens),52mm tb,ported plenum,edelbrock runners and base,headers with 3" catback,tb coolant bypass,afpr@44 psi,msd 6a w\blasterII coil,3.73 posi,sf connectors and corvette servo
in my camaro before the mods i went 115 and she was riding real smooth. im a friends old 87 iroc w/ a 383 and 671 blower we hit 167. he said he got it up to either 178 or 187 when he started to scrape the ground.
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension. MSD probillet distributer/ coil,
90rsmustangkiller.. you did this in Mass
..what highway?
K&N
Flowmaster 80
Daily driver:
AIM: RyanNH84
..what highway?------------------
K&N
Flowmaster 80
Daily driver:
AIM: RyanNH84
After i swapped my stock 85MPH speedo for a '93 model 140MPH speedo, i took it up to I-95 just belonmg the NH border and opened the car up. It was at the widest part of I-95 (5 lanes) and it was 2AM.
I got all the way up to 140MPH before I let off....damned if i'll ever do that again. I double checked my speed by math and it came out to about 137MPH.
This was with 2.73's
now i'm chicken to go past 80MPH on public roads...just not worth it
Mike
--Black '88 Mustang LX 5.0L AOD--
BBK Headers, Off-Road H-pipe, MAC 2.5" Cat-back exhaust, UD Pulleys
3.73's, FMS "C" Springs, Tokico Shocks,
'93 Pony rims, Saleen Spoiler
5-spd swap VERY soon
-14.42 @ 98MPH (w/ 2.4 60-footer)-
Mike
had my 2.8 up to 135 according to a 97 z28 camaro speedo. had my 2.8 beretta with nos at 143. i will never go that fast on a freeway ever again. that exit came out of nowhere...
1995 Camaro
3.4 with 4L60E
Stock...for now
Currently being redone:
1988 Camaro
2.8 with T5
threw a rod...
Soon to have a 350 TPI out of an '85 vette...
http://www.nothingssafe.com
1995 Camaro
3.4 with 4L60E
Stock...for now
1988 Camaro
2.8 with T5
threw a rod...
NOTHINGSSAFE- 143 in a beretta? 138 in a 2.8 Camaro? I smell bull****. I mean really, the 2.8's bottom end sucks ***. If you had a 2.8 built for NOS, You would have ran out of juice anyway. But then, if you had built a 2.8 why didnt you put a 3.1 in its place, it bolts right in(beretta). or a 3.4, 3.8, or a SC3.8. All will fit with minimal modifacation and are alot stronger of an engine. I'm not trying to make any bad blood between us but come on. Your right that you could build a 2.8 to do that but it would be more worth your while to have put a v8 in the camaro.
You have walked onto the biggest baddest dog porch and you will be dealt with accordingly.
I'd rather be historically accurate than politically correct!
[This message has been edited by LottaBallsCamaro (edited October 28, 2001).]
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Ran for about 20 miles at 105 with the cruise control on. I-95 South from Washington DC in the HOV lanes at 3:00 AM
I must either have a death wish or really want to go to jail.
Racnoth, you're right, cause your poontang got walked on by the Camaro it was racing.
155mph according to the MPH calculator on this page. 5200rpm in 5th with 3.73 gears. I think it would pull redline (6600) in 5th, really didn't seem to be breathing heavy at all.
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor...no traction
110...
in my 3.1, on a small country road...
scared the (poop) outta me...
then 100 the other day on the fourlane... it was sooo smooth.. i loved it... hahaha
but that was in 4th gear, we were on a slight uphill grade and when i put it in 5th she dropped to bout 98
that sucks... but oh well
it was fun
it was fun
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
95-100 not sure cause it don't tell me past 85
but I only speed that much on open highways where cops are easy to spot... the dash shakes a little at those speeds, but nothing serious...
1984 Firebird - Daily driver, 305 LG4, 3.23 rear, T5 - Hurst short shifter, Edelbrock 600 CFM 1406 carb, Performer intake - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 5 Spoke Wheels, AIWA bargain basement (from Sears of course) CD player, Eight-ball shift ****
Check out my ride here
"IT'S SNOWING! TO THE HIGH SCHOOL PARKING LOT!" - The Mustang and Firebird face off in the dead of winter.
but I only speed that much on open highways where cops are easy to spot... the dash shakes a little at those speeds, but nothing serious...------------------
I really hope it is a deserted road where you guys are making these 125+mph runs
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback being installed next week
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
*1989 RS
*355 CID
was a faily deserted road, two lane texas road, 4 in the morning. And just a question for BOWTIROC.... Whatca talking about?
<font face="Verdana, Arial" size="2">Racnoth, you're right, cause your poontang got walked on by the Camaro it was racing.</font>
<font face="Verdana, Arial" size="2">Originally posted by LottaBallsCamaro:
</font>
</font>
the 138 in my camaro is right next to the z28. after we were done, he told me what he was at untill he pulled away. and the beretta is from tailing behind my friends built 5.0 stang. im not tryin to BS, i hate whne people lie
, i am just telling you what i know and was told. the reason i didnt do much to the 2.8 in the beretta is cause i was just a poor 16 year old with a 5.50 an hour job and little mechanical experience. trust me, if i knew then what i do now, things would have been much better( and i wouldnt have a blown engine!)------------------
1995 Camaro
3.4 with 4L60E
Stock...for now
1988 Camaro
2.8 with T5
threw a rod...
Well, It started with me racing a new Civic Si w/a fart muffler. I tore him a new A-hole and at about 60MPH I slowed down as he was about to do the 100MPH blow by, well not that night. He got up next to me and a punched it to the floor and I hit about 135, he was sooooo far back I let off. Fun times
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, Custom Burned PROM, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler,
88 Formula 350
Had my GTA up to 153 with still about 1/2 of 4th gear left.. backed off when I realized I was doing almost 4x's the legal speed limit (45mph..) I dunno if this counts as a highway, but same thing
Gotta love the digital dash.. I swear officer, I was goign with the flow of traffic (!&*^@!&@^
Decently worked 87 GTA; finally got a good time out of her: 12.72 @ 116.4mph
Gotta love the digital dash.. I swear officer, I was goign with the flow of traffic (!&*^@!&@^------------------
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
A few of you have said you were doing X MPH and still had half or so of 4th or 5th gear left... this is somewhat false, in top gear you will almost never have the torque or Hp to redline... That is why top speed in a 5 speed is often in 4th gear and 5th gear for a 6 speed, we know that several thirdgens can push ~150, but thats probably it aside from TTA's and other special performance packages... I'd say that's insanely fast anyhow, hope you guys are careful.
Edit, this isn't directed towards anyone, as ben states above he's running 12's... which is MUCH better than stock.
[This message has been edited by ChillPhatCat (edited October 29, 2001).]
If you are gonna talk smack about you mustang being fast, expect it back. If I misunderstood your comment, I apolgize. Just looking out for my 3rdgen boys.
stock 305 auto with 3.73 gears with speedo way off at about 4 grand in od how fast would that be with stock tires and everything?
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
91 z-28 305 700R4
3.73 gears out back
CPC.. I see what you're saying, but as far as my speed you're wrong... I forgot the name of the mod, but it fixes the not shifting into OD @ WOT... but, when winding out, and it shifts into 4th (OD) it doesn't magically stop accellerating
Granted it doesn't pull as hard, but it does pull....
Granted it doesn't pull as hard, but it does pull....------------------
i dont think that thing would get much over 105 if that
