Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
0-60 times
Old Nov 14, 2013 | 07:56 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
0-60 times
I haven't raced this motor yet but I was wondering what my 0-60 time would be for a roller Chevy 355 with Forged pistons, LT4 Hotcam, Holley Stealth Ram, 24lb bosch injectors, Pro Comp aluminum 64cc heads with larger than stock valves and 1.6 RRs, longtube headers, with a 700r4, and a 2.77 rear end gear? This is with the transmission in drive shifting at 5200 rpm (havent changed out the springs yet). I want to see what people here say. I'll tell you that it feels a lot quicker than stock.
Also, post your 0-60 times if you know them.
Old Nov 14, 2013 | 11:00 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: 0-60 times
Not great. 2.77 gears are not a great choice for anything but a land speed racer. If you have a stock torque converter, that is not good either.. This driveline combo plus the fact that you built a higher rpm engine(higher than stock) does nothing but kill 0-60 times. I bet it runs well in the 1/4 mile though. I dont know anything about pro comp heads but it sounds like a 375+hp combo. 2.77 gears/stock converter makes it accellerate like a 300hp combo.. high 13's.. Get gear/looser converter and mid-high 12's is probably possible! Goodluck!
Old Nov 15, 2013 | 09:21 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 0-60 times
Pro comp heads and a LT4 hot cam... Ouch I am sorry that is a really bad combo. Those heads don't flow well at all below 500 lift. Glad you did the 1.6 RRs
Although it should make ok power but with that rear end, maybe 5.5 - 6 seconds.
Old Nov 15, 2013 | 11:46 AM
Re: 0-60 times
I'll be upgrading the transmission with a stage 3 shift kit in the Spring, then eventully install a 3.27 or 3.42 gear in the rear.
Old Sep 9, 2014 | 12:00 PM
rb85TA's Avatar
Car: BUILDING 1985 HARD TOP T/A
Engine: sbc
Transmission: stick
Axle/Gears: GM
Re: 0-60 times
Are you wanting to drag race, road race, autocross or just an all around street/ strip & drive it to the mall?
Old Sep 26, 2014 | 08:11 AM
Re: 0-60 times
It was more aimed at street/race course driving. I no longer am working on the project.
Old Sep 26, 2014 | 08:17 AM
rb85TA's Avatar
Engine: sbc
Transmission: stick
Axle/Gears: GM
Re: 0-60 times
Sorry to hear that! Hope you can eventually get back to it/ or at least to the point, that you can start over.
Good luck 😀
Old Sep 26, 2014 | 08:21 AM
Re: 0-60 times
Good luck 😀
TreDeClaw
Jun 22, 2021 08:21 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
