What's the difference in a Trans Am and a Firebird?
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Just to clear something up....The Trans Am's ground effects are not at all heavy. When I painted my 89 GTA (all the same gfx), i took the gfx off and weighed them. ALL OF THEM (nose, rear bumper, and sides) weighed about 17-18 pounds. That is not going to make any difference at all. Considering the general rule of thumb with a car is every loss of 100 pounds is worth roughly .10 in the quarter. Just want to let people know before they say their car is heavy due to ground efffects.
Car: 1984 Z28
Engine: 454
Transmission: Th400
A Formula 350 has a 350 in it. They started putting 350 on them to show that they didn't have a 305 in them. When they first started using the name formula on firebirds they had 400 and 455 pontiac engines in them.
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
I also agree that GTA's aren't all that much heavier than a Formula. Glenn91L98GTA weighed his car and I was surprised how light it was, I think it was 3,4xx. I'm not sure where the myth of a GTA's heavy weight came from, but when people report the weight of their GTA's on this site; it is not all that huge.
Originally posted by ATOMonkey
Is GM still sending the SS's and TA's to SLP for the upgrades or are they doing them in house now?
Engine: Twin 454's
Originally posted by iroc22
Well I think it came from the fact that GTA's came with a bunch of options standard. Take a look at the weight table under the tech data section on the main site; it sure adds up.
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, I definitely misworded myself there. Obviously that is where the myth came, but the fact is that GTA's are rarely heavier than loaded Formula's or IROC's, etc., at least to any consequence.
I have to agree with IROCZTWENTYGR8, GTA's were the heavier of the three. But are IROC's really lighter then formulas? I thought it would be the other way around, due to some of the extra weight the IROC has. I know the 1LE camaros were lighter then the formulas, well corect me if im wrong.
87 Test:
IROC-Z 5.7 Auto: base/3,341lbs. as tested/3,341lbs.
GTA 5.7 Auto: base/3,476lbs. as tested/3,581lbs. (Optioned)
IROC-Z 5.0 5-Speed: base/3,250lbs. as tested/3,355lbs. (Optioned)
Formula 5.0 5-Speed: base/3,383lbs. as tested/3,383lbs.
It was noted that Firebirds are at least 130lbs. heavier than Camaros when base on all models, and how the optioned out IROC was still 28lbs. lighter than a base Formula. Those are the results.
Engine: Twin 454's
Originally posted by IROCZTWENTYGR8
87 Test:
IROC-Z 5.7 Auto: base/3341lbs. as tested/3341lbs.
GTA 5.7 Auto: base/3476lbs. as tested/3581lbs. (Optioned)
IROC-Z 5.0 5-Speed: base/3250lbs. as tested/3355lbs. (Optioned)
Formula 5.0 5-Speed: base/3383lbs. as tested/3383lbs.
It was noted that Firebirds are at least 130lbs. heavier than Camaros when base on all models. Those are the results.
87 Test:
I stand by my comment on how the weight difference (using the factual amount of Glenn's) and the 3341 IROC 5.7 is fairly negligable.
That said, I am highly impressed with the weight of an IROC. How much would the lack of airbag from the '91 '92's make? I'm curious.
Good info and interested in your reply.
Edit=removed "in" from first sentence. Added "fairly" after IROC 5.7 is.
Things can vary of course depending, but you get the idea. I *heard* air bags added 20-25lbs., don't quote me there though.
Engine: Twin 454's
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
I think what he was saying is that they are really alot closer than most people say. The gta base model already has tons of options that the formula and the camaro base didnt have. so when you add those options to the formula and camaro the weight is closer. At any rate 100 lbs is roughly 1/10 of a sec. whooop deeee
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
