What would this modded 98 civic VTEC run??n
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Low to high 16 if it's stick and mid 17's if it's auto...
The intake might add 3 Hp (with header) and exhaust and header may be good for 13 Hp, just exhaust would probably be about 8 Hp... these figures would be at the crank.
127 Hp Stock + 16 = 143 Hp w/ header and 137 Hp w/o.
Considering it's about 500 lbs lighter han a thirdgen and about as powerful as a V6 thirdgen I'd say it runs a little faster than a v6 thirdgen... This takes into consideration that adding these free flowing items kills what little torque it had (like 120 lb-ft) probably dropping it to about 105 which is much worse than the 2.8L V6 with 160 lb-ft and thus making a weak launch off the line.
This is just me using common sense and general figures I've seen tossed around, the effect of header(s) and exhaust is diminished with such small torqueless I4's... It may all be speculation, but most people will probably agree.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
SI prolly runs low 15 and if the guy knows how to launch might, prolly not but might, hit a high 14
anything else I would say high 15 low 16
Actually probably like a high-mid 16, if that, as long as it's not a Civic Si.
