T-5 Transmission Question...
I tryed to find out exactly what part's were different/stronger but couldn't find a part's breakdown, I did however find a bunch of info saying that it is only rated for 305 ft/lb's which mean's it can't be that much stronger then the regular t-5, definately not worth going to the effort to replace for a performance improvement...........sr
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
T-5 wc
The bearings are stronger, the case is too and the syncros are different that's why they use ATF.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Re: T-5 wc
RP.
1988+
The WC T5 Borg-Warner first showed up in fall of '87 with the new 1988 model year.
FYI: the T-5 showed up in mid-84 and was not modified by Borg-Warner (under GM license) until 1987. Lotsa warranty claims at GM with the original unit. This is how they new the 350 wouldn't work -- they (GM) would go broke on T5 warranty claims.
RP.
RP.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
