my rpo codes for you's whow anted them!
hey guys yesterday i took my car to my buddy who works as a gm mechanic in newmarket here.....he gave me a sheet of my coes for ym camaro.....infact its not a players challenge car as we had thought it was.....it is indeed a true 1le car tho.....here's my codes.....sorry if i type some wrong im kidna in a rush....k here we go.....am9-an4-ar9-au3-ao1-a31-a90-b18-b34-b35-b84-cd4-c41-c49-dc4-dg7-d34-d42-d75-d80-e52-e72-e92-fe2-gm3-g80-g92-1pc-jg1-j65-kc4-ko5-k68-lb9-mk6-mm5-na5-np5-n33-n64-n96-qdz-r7f-r7k-r79-r7u-tr9-tt4-t93-ua1-ub3-um6-uq1-u19-u25-u26-u29-u79-van-vk3-v73-ww1-w62-z28-z31-z49-1le-11q-15p-19c-191-199-40u-6db-7db-8nn-9nn-90a ok thats all of them for now.....i mgith of type a few wrong or whatever.....oh and heres the vin# 1G1FP21F3KL155592......hope i typed it all right.....i didnt have time to chekc what they allw ere.....can u guys spot fo whatever what some of them r....and whats the weight differance between a 1le and stock iroc?.....thx for your help guys...irocker,nblanchard,palric r jsut a few to name...and nice cars guys....
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
Here is a breakdown of some of your RPO's
You might of misstyped a few. Hope this helps...
I noticed you also have the aluminum driveshaft, lucky you...
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
Unable to locate code AO1 in our database!
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 : ORNAMENTATION, INTR, DELUX
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C41 : HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
C49 : DEFOGGER, RR WINDOW, ELECTRIC
DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D34 : MIRROR, VISOR VANITY
D75 : HANDLE, O/S, DR
D80 : SPOILER, RR END PNL
E52 : DOOR RR, 83 INCH, WRAP AROUND
E72 : BODY LENGTH, INCR I8 INCH
Unable to locate code E92 in our database!
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GM3 : AXLE REAR, 3.45 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
G92 : AXLE REAR RATIO, PERFORMANCE
Unable to locate code 1PC in our database!
JG1 : SHAFT, PROP, ALUMINUM
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 : COOLING SYSTEM, ENG OIL
Unable to locate code KO5 in our database!
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N33 : STEERING COLUMN, TILT TYPE
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
N96 : WHEEL, 16 X 8, CAST ALUMINUM
QDZ : TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
Unable to locate code R7F in our database!
Unable to locate code R7K in our database!
Unable to locate code R79 in our database!
Unable to locate code R7U in our database!
TR9 : LAMP, GROUP
TT4 : HEADLAMPS, HALOGEN, 4
T93 : LAMP, TAIL & STOP, SPECIAL
UA1 : BATTERY, HEAVY DUTY
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1 : RADIO PROVISIONS, FOR STEREO
U19 : SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
U25 : LAMP, INTR, RR COMPT, COURTESY
U26 : LAMP, INTR, ENG COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WW1 : APPEARANCE PACKAGE(WHITE), AERO #l
W62 : ORNAMENTATION, AERO PACKAGE
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
Unable to locate code Z31 in our database!
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
1LE : PERFORMANCE PACKAGE COMPONENTS
11Q : MOULDING COLOR, WHITE
15P : WHEEL COLOR SILVER METALLIC (91)
19C : TRIM COMBINATION, CLOTH, BLACK (C) (91)
Unable to locate code 191 in our database!
199 : SEAT BELT COLOR, BLACK (91)
40U : PRIMARY COLOR, EXTERIOR, WHITE (91)
6DB : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NN : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
9NN : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
90A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/DK AUBURN (91)
TR9 : LAMP, GROUP
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
THX for the post !
Well too bad about the RU7 option but CONGRATS on the 1LE. A bona fide true blue the real mccoy 1LE car !
A 1LE car is a very rare unit and I am glad to see it worked out for you in the RPOs. What is even rarer is it is an LB9 (305) with stick and t-roofs. I think yours is the first I have seen of this combo.
How many kms are on the car ? Also you should take a ride over to http://www.1LE.net and register your car. You ought to be able to learn alot about the uniqueness of the option from those guys.
Do you plan on restoring the car ?
RP.
RP.
I was under the assumption that 1LE cars came with no power accessories. In the rpos is lists power windows and door locks, unless I'm reading them incorrectly.
Does your car have power windows and door locks?
I just looked on 1LE.net and he does have a Players Challenge car. The RPO for the PC is R7U. Also, there is another PC car that has electric windows and mirrors, so I guess you could get them that way.
Congrats dude!
Congrats dude!
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Originally posted by nblanchard
R7U was an unknown code according to Kevin.... unless he made a typo (like he usually does
If you look closely, you will see the rpo that he posted was R7U
I know Kevin.. I was tlaking about him, he always has typos... so maybe the R7U was supposed to be RU7, or maybe palric made a mistake. Either way, both codes don't show up in the RPO decoder.
palric said the Players One code is RU7, right? And 1LE dood said he has R7U... can a RPO code be soo close like that?
I'll check into it
I can't remember if I have seen power doors and windows in a PC car. Doesn't make sense if you have a wreck you need battery power to operate these and they pose a weight penalty as well ? I'll check into this as well but I've never seen tilt, windows and locks in PC cars. Also, if R7U turns out to mean the same as RU7 how to you explain the t-roofs ? Did 89rock1le say he had them installed ? The car has stereo options as well -- I don't know if there was a special code for radio delete -- other than RU7.
gotta go,
RP.
hey
um yeah the car does have tilt and power everyhting....whioch i was thinking they woudltn put into a pc car...also the t-tops are aftermarket and the guy from before who owned the car had them put in.....so the dealership tells me....and when i bought the car the dealer asked me if i want the roll bar for it?....i said no thx not knowing that it might of had somehtign do to with the car history or whatever...etc....etc....but yeah the car has a custom paint job and t-tops now.....but the original colour was white cuzz u can see a lil spot in the door jam area...like a fignernail size spot....
Re: hey
RP.
doing some homework
I have made a few calls to guys I used to know who either owned or raced these PC cars, asking about what was and what wasn't in regards PC cars. They pretty much choke and puke at the notion of a PC car with any power options. They used to race them but that was along time ago and here we have somebody with the right RPO and fully loaded at that. Makes you wonder what is fact and what is fiction ? One guy says this, another that and 1le.net something else ?
S0 I am going to try and find out if there is still anyone at GM who knows about this stuff and I am going to find out if there is anyone in the Players Cigarrette company who still knows about this stuff ? If I find out anything interesting I'll make a post.
RP.
RP.
