Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Tune Up Complete and results
Old Aug 3, 2002 | 12:31 AM
Slade1's Avatar
I ended up with these parts
Borg Warner 8 mm Wires
Borg Warner Cap (Brass)
Borg Warner Rotor (Brass)
MSD GM Blaster Coil
MSD 8.5 mm Coil Wire
AC Delco Plugs
Results
Idle improved from <500 RPM to 650 RPM when in gear
Idle is a lot smoother overall
Cold starts are back to normal start times
Noticing the header restrictions A LOT
I'm still in the process of testing for stall events, so far so good, much more responsive...
Old Aug 3, 2002 | 02:10 PM
nblanchard's Avatar
What method did you use to mount the MSD coil?
Old Aug 3, 2002 | 03:58 PM
Slade1's Avatar
The coil mounts to the same spot as before... just had to drill out the riveted brackets on the old one...
Old Aug 3, 2002 | 04:30 PM
nblanchard's Avatar
Yup.. ok.. just wondered what ya did.. I did the same thing
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
