Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
swap rear gears and VSS upgrade
Old Aug 24, 2002 | 03:32 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I was thinking about installing some 3.73s (from 3.42s) and know you have to by new gear for the VSS at the same time. Does anyone know of any sources around South Ontario, GTA, KW, etc who can supply these ? Anyone done it before ? I'll want to get the right setup for the VSS to read true to the speedo.
thx much,
RP.
Old Aug 26, 2002 | 02:55 PM
88redxtsy's Avatar
I'll be installing my 3.73's in over the winter but won't be worrying about the proper speed. I dealt with that problem for 4 years until I installed the 3.08's. Surprisingly, my speedo is perfect know with the 16" and 17" rims. Then again that could be because the two are almost the same height maybe be off by even half of an inch.
But if you do want the right speed than you need to purchase two speedo gears that go into the transmission. Theres an article on the board somewhere that explains to you which gears you need to order from gm (provides part number) according to which gear ratio your installing. You could probably do this yourself.
I hope I answered your question or even provided some help. Probably not
Where's Slade1 when you need an answer!!
Old Aug 26, 2002 | 03:55 PM
Slade1's Avatar
Slade1 says go to GM parts department and ask for speedo gears pertaining to the ratio of the rear end.
Very cheap and easy to do, provided that gear ratio was offered by GM... doesn't matter if auto or stick..
if not, we can do the "figure out which color gear pertain to the right ratio" brain drain...
Old Aug 26, 2002 | 05:33 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
3.73's where offered on the '84 L69 5 speed cars. Gm has a reference chart with all the colors on it. You could also buy a translator box since you have a VSS. That would allow for any wheel or tire upgrades in the future.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
mizz0313
Aug 12, 2015 06:45 AM
