Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Need Repair Advice!
Old Sep 13, 2002 | 11:26 PM
cAr_KrAzY's Avatar
Need Repair Advice!
I am fixing up my '85 Z28 and when I removed the GFX The studs were so seized they broke off. What can I do to get these studs, or have them replaced. I need help!!:hail:
Old Sep 14, 2002 | 05:39 AM
Eric2ndGen's Avatar
Screw extractors, 'easy-outs', lots of penetrating oil, etc. etc. etc.
However- after you've tried all this stuff, usually with nothing but alot of frustration- you may want to weld another bolt to the broken one in order to remove (heat from welding also helps loosen things up)- however- you had better have been planning on bodywork and a paint-job if going this way (I assume the studs [formerly bolts] are stuck in the body- not the soft ground effects themselves).
Old Sep 14, 2002 | 08:53 AM
cAr_KrAzY's Avatar
The studs or bolts are stuck in the GFX. When I removed the nut off the bolt it snapped off. There is still a bit of the bolt visible but it is in the GFX. I am planning on new paint and body work. Where can i get new ones studs/bolts?
jaridjohn
Oct 5, 2015 07:01 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
