Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Water temp sensor HELP HURRY!!!!!!!
Old Sep 15, 2002 | 12:08 PM
ROCHEAD's Avatar
Im currently under the car. go to your car and find the sensor. its beside the number one spark plug, on the drivers side(if you don't know where 1 is hehehe) checkj to see how many wires are going in the connector. the instructions say there are two, but theres only one that i can see. maybe i have the wrong conector but i can't find any other connectors. just for the record, i had a after market guage on it, so i had to change the sensor for which it cam from, in all im going to put the original back on and i can't find the original one i took out, i bought a new one and it casme with a new connector, with two wires. HURRY up it will be most helpful.............No don't go check out another website, go check hahahahhaha thanks in advance...
john
Old Sep 15, 2002 | 12:26 PM
Slade1's Avatar
The temp sensor near the 1st cylinder has only 1 wire.
That's the sensor for in dash only as I recall.
Old Sep 15, 2002 | 12:28 PM
ROCHEAD's Avatar
thank you, but where did the wire come from, under the block aream with the oxygen sensor comeing from the sdame plastice covering????????????????? thats what i get
Old Sep 15, 2002 | 02:33 PM
ninety1TAgta's Avatar
Yup I just checked. 1 wire and it goes to the left a little bit under the block. About half a foot down the wire from the temp sensor (which goes a towards the rad and down) it meets up with the o2 sensor (tie wrapped or loomed together) wire then they both disapear under the block.
greg
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
