Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Camshaft question....
Old Sep 29, 2002 | 02:45 AM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
i have the Lg4 engine.,....whats the best camshaft for it without having to modify everything else...basically a straight swap.!
Old Sep 29, 2002 | 09:54 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Most likely the Comp 256XE , any other mods to the car?
Old Sep 30, 2002 | 12:06 AM
Idlehands's Avatar
Car: 1985 Trans Am
headers-dual pipes-K&N filter-accel sparks and coil.....
Old Sep 30, 2002 | 07:35 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
more cam
I had a 217/225 .505/.525 roller on my L03 which was way too much for the speed density system to deal with (custom chips or otherwise) but it was ALOT OF FUN nonetheless.
The 256XE is 218/224 and .465/.477 with 1.6s would gross .496/.508 and 1-3 more degrees timing. That would work well if you are straight carb if electronic carb... start snipping wires or something... no just kidding if E-carb then max cam is going to be around 204/210 duration.
my .02 cents worth,
RP.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
