alot of codes for 20$
i just paid 100 bucks for this ta and then cleaning it out i found 80 bucks under the seat= car for 20 bucks check these codes out for $ 20
Here are your results:
AAA : 4-WAY MANUAL SEAT ADJUSTER
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
Unable to locate code E6N in our database!
N33 : STEERING COLUMN, TILT TYPE
WS6 : PERFORMANCE PACKAGE, SPECIAL
67C : TRIM COMBINATION, CLOTH, LT CAMEL (C) (91)
AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
B91 : ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
GU5 : AXLE REAR, 3.23 RATIO
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
Unable to locate code WV1 in our database!
67I : INTERIOR TRIM, LT CAMEL (91)
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
G80 : AXLE POSITRACTION, LIMITED SLIP
N78 : WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS
Unable to locate code W69 in our database!
Unable to locate code 67M in our database!
AM9 : SEAT, RR, SPLIT, BACK, FLDG
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
PB4 : LOCK CONTROL, WHEEL
Unable to locate code W82 in our database!
679 : SEAT BELT, COLOR,LT CAMEL (91)
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
C49 : DEFOGGER, RR WINDOW, ELECTRIC
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
QYH : TIRE ALL, P215/65R15/N WOL R/PE ST TL HWY
YR1 : SEAT,FRT CUSTOM
7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
AU3 : LOCK CONTROL, SIDE DR, ELEC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
K64 : GENERATOR, 78 AMP
T93 : LAMP, TAIL & STOP, SPECIAL
YS1 : SEAT,RR CUST
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
A01 : WINDOW, TINTED, ALL SHADED, W/S
C95 : LAMP, INTR, ROOF, COURTESY AND DUAL READING
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
YT1 : BUILD UP DR & QTR
9NM : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
A31 : WINDOW, POWER OPERATED, SIDE
Unable to locate code DO2 in our database!
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
UU6 : RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
D1U : GEAR, SPEEDO DRIVEN
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
Unable to locate code YO6 in our database!
BS1 : INSULATION, ACOUSTICAL PKG
D27 : COVER, RR COMPT, TRUNK STOW
Unable to locate code NM4 in our database!
U23 : CLUSTER, INST, TRIM ODOM
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
BV8 : ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
D34 : MIRROR, VISOR VANITY
NM5 : EMISSION SYSTEM, CANADIAN REOUIREMENTS
U73 : ANTENNA, FIXED, RADIO
Unable to locate code 55P in our database!
B20 : ORNAMENTATION, INTR, LUXURY
D35 : MIRROR, OUTSIDE REAR VIEW
NM6 : EMISSION SYSTEM, RECALIBRATED
U81 : SPEAKER SYSTEM, RR, DUAL
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
Unable to locate code D60 in our database!
Unable to locate code N0D in our database!
VD6 : BUMPER PROVISIONS, FRT, ALUMINUM
62L : SECONDARY COLOR, EXTERIOR, LT TAUPE (92)
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
D92 : STRIPE, EXTR DR HANDLE
NP5 : STEERING WHEEL, LEATHER WRAPPED
VK3 : LICENSE PLATE, FRT MOUNTING PKG
62Q : MOLDING COLOR, LT 8EECHWOOD MET (91)
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
E5Z : SPEEDOMETER ADAPTER (DELETE)
Unable to locate code NO9 in our database!
V73 : ANTENNA, FIXED
62U : PRIMARY COLOR EXTERIOR, LT BEECHWOOD MET (91)
YS1 : SEAT,RR CUST
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
That's pretty cool I would have said that even 100 bux would have been a good deal but to find 80 bux even sweeter. Nice find to bad for the previous owner. Thread
