Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Compression Test
Old Feb 21, 2003 | 04:15 PM
theREIS's Avatar
Compression Test
I need to do a compression test on my car. I need to know the pressure that the guage is supposed to read. I looked in my haynes manual but it doesnt say.
Old Feb 21, 2003 | 04:45 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Well it should be around 130 - 160 psi depending on mileage and what not. And you shouldn't get a huge gap between each Cyl. So if one is at 150 psi, and the other is 120psi, you've found a problem.
Old Feb 21, 2003 | 05:10 PM
Slade1's Avatar
Here's some quick thoughts on compression tests...
Less than 5% variation between cylinders = good...
Squirt a bit of oil inside the cylinder being tested, run the test.. if the compression goes up dramatically, you've got o-ring problems...
Compression varies with engine type, heads, ci, combustion chamber size etc...
Old Feb 22, 2003 | 11:44 PM
Steve89GTA's Avatar
The actual reading isn't nearly as important as the variance. Just make sure that all readings are similar.
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
