Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Oil leak ...
Old May 3, 2003 | 07:06 PM
BluthndrZ28's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Transmission: 700R4 w/2600 stall
Oil leak ...
I noticed an oil leak that seems to be coming from the manifold. Upon a closer look one of the bolts is missing. Is it possible for the oil to be coming thru the open bolt hole?? There doesn't seem to be another place where the leak could be coming from, so I'm hoping it's due to the lack of the missing bolt. Any insight into this would be greatly appreciated. Below is a pic where the bolt should be.
Old May 3, 2003 | 09:50 PM
'89 superbird's Avatar
I think that bolt hole is for an option that yours and my car does not have. I am missing the same one only don't have a leak. Anybody know what goes there??
Old May 3, 2003 | 10:36 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i am not 100% sure but i believe that is the EGR valve and a bolt does not go there unless you want to block it off?
Once again I might not know what I'm talking about
Old May 3, 2003 | 10:44 PM
chubb rock's Avatar
Last spring I had some engine work done. Mostly freshening up the engine, having seals and gaskets replaced.
When I finally got the car back, I noticed (after driving it for a few days) that a leak had sprung. A small puddle of oil was lying in one of the intake manifold nooks. It took my mechanic 2 tries before he finally stopped that leak.
The problem stemmed from one of the bolts that held the intake manifold down. The pressure of the engine was driving some oil up the bolt to the surface of the engine. The car is original, so the bolt was obviously defective from the factory, but the leak is no more.
Chubb
Old May 3, 2003 | 11:18 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I don't think that the lack of whatever it is that might have been attached to that little thread is the cause of your oil leak.
Old May 4, 2003 | 07:12 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Let me affirm to you that you dont know what youre talking about and you are 100% wrong...lol j/k
That boss is not for the intake to head bolt..Its either for a clip that holds the harness or for a wire loom..What side is that?
Daz
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
