Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
sway bar?
Old Jul 1, 2003 | 07:05 PM
icebird_1981's Avatar
sway bar?
k i am new at haveing all this power so dont laugh at me. k u no when u got WOT and the back of the car flings around (scary $hit)
i thought the sway bar was suppost to stop this from happening. is there anything i could do to fix this? like a performance sway bar or something?
oh also were do u people got for dyno testing i wanna get mine done?
Old Jul 1, 2003 | 08:24 PM
(BR)G-Machine's Avatar
Scary ****!?!?! you spoiled SOB, that is just POWAH!!
O well, if you want to hook it up sway bar is okay if the rear axle is torqueing that mauh and you are litterally doing wheeled burnouts. Could also thingk Panard bar, adj. torque arm or lca relocation brackets.
Old Jul 2, 2003 | 09:46 AM
Eric2ndGen's Avatar
I believe what you are referring to is power steer (not power steering)- just like torque steer on a front wheel drive vehicle- but the reverse.
Sway bars do not have anything to do with solving this. You have a gear climb situation and a posi unit that's probably less than perfect. The solution- make sure posi is in good shape, and get more weight over the passenger rear wheel to keep it from pulling as easily (unless you got some other issue going on, your rear would be pulling the car to the right- i.e. passenger side). How you get more weight over that wheel is your decision- get an adjustable control arm setup- install an adjustable airbag on that side to raise that corner of the car- whatever.
If this disturbs you, you don't want to fiddle and spend money here and there and you can't drive the car effectively as a result- dump the gears you have (i.e. assuming 3.23's or higher- numerically) and go with something more highway-friendly and that won't generate much torque at the wheels at low RPMs.
Old Jul 2, 2003 | 04:20 PM
ya it freaked me out because this is the fist time i drove anything other then a v6, i just assume that the car slideing to one side does not help in a race. as i said i am new at the whole power thing, but i am likeing it!!!!!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
