Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
+1 clutch
Old Jun 12, 2004 | 03:13 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
+1 clutch
hm.. anyone keeping track lol
driving yesterday... push the clutch down switching from 1st to second... for some reason it stays down and then jammed...
popped into neutral... can't get it into any gear... i push the clutch down but can't get it into any gear at all...
anyway, screw cheesy aftermarket clutches. took it to a new guy he's putting a centerforce in... should've done this logn time ago.
Old Jun 12, 2004 | 08:13 AM
85rocker's Avatar
git yor flywheel surfaced and balanced with clutch
Old Jun 12, 2004 | 02:11 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
A stock clutch is more then enough for the power your putting down. You need to take some driving lessons. I should school you some time...
Old Jun 12, 2004 | 09:51 PM
johnyIROC's Avatar
no comment.
Old Jun 12, 2004 | 11:03 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: +1 clutch
First, you're an idiot. Ok, now that i've gotten that out of the way.....
Dude, get the problem that is causing the clutch failures fixed. You shouldn't have to replace your clutch every other oil change.
Old Jun 13, 2004 | 04:43 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: +1 clutch
that getting it back into gear part I went through
and I sheared off my teeth on the synchros to my tranny....and shattered 2nd gear
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
