Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Spoiler job in progress...
Old May 16, 2005 | 09:10 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Here is our spoiler job..
Old May 17, 2005 | 03:19 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
so heres the reason for this job...
The plastic clips that go onto the hatch that fit into the aero style wing are no longer being made by GM or infact anywhere.
So we were kinda stuck with a spoiler that couldent use it for anything. So we took it upon our selfs to figure out a better use for it. here it is..
Old May 17, 2005 | 05:05 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I've seen urathane (sealant for windshields) used to hold on the sides instead of clips. Tape it in place till the urathane sets up. Works fine, can't tell at all.
If the reason the spoiler was sanded down to the rubber is due to small cracks, they will reappear with new paint and there is nothing you can do about it. I learned that the hard way.
Old May 17, 2005 | 07:03 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
well the first time we sanded it all down, thinking we can go to the dealership pick up the clips.. no problem.. well yes problem.. no more clips and we just figured lets play with this see what we can come up with. I think its nice. We are going to try to take it all down. We got bondo to of course.. make it look good and than paint. easy as that.
Old May 17, 2005 | 07:25 PM
Engine: SBC, LS-x
If there were cracks in the paint then they will be in the rubber wing. Just little tiny cracks but they will crack right thru the new paint again. It sucks but there is no way to fix it.
I prepped the stock wing just like you did a few years ago. Looked perfect right after it was painted but don't touch it. Body guy couldn't even get it on the car without numerous cracks showing up again right away. At least he didn't charge me for the paint. I was having a rear quarter painted due to a supermarket employee's mishap with a load of shopping carts. In the span of a couple of months, it looked no better than it did before it was repainted.
Old May 17, 2005 | 07:55 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
well
damn GM
Old May 17, 2005 | 07:58 PM
trigger GTA's Avatar
Car: 92 TA vert
i like the cut down version of the wing. i think it looks good
HalfInchWrench
can you not lay down a layer of fiberglass to stop the cracks from reforming?
Old May 17, 2005 | 08:11 PM
Engine: SBC, LS-x
HalfInchWrench
A thin layer won't stick and if you make it thick enough to support it's self, would be too big. I've spent many hours swearing at those wings. Why oh why could they have made them out of fiberglass . Can't repair that composite over foam over metal at all. I think the outer layer is neoprene or some other fancy rim injection plastic.
Old May 17, 2005 | 08:15 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
May not be a solution, but that looks like a pretty good idea.
Old May 18, 2005 | 09:59 AM
87LG4FORMULA's Avatar
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
Nice pics, let us know how it turns out. I have the same cracks etc and some nice warpy bubbles too!
Old May 18, 2005 | 06:52 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
finished the project, turned out alright .. better paint would be nice..
Old May 18, 2005 | 08:31 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
That looks pretty good Dave.
Why the hell did GM make those spoilers out of the same stuff they make Nerf footballs out of? Mine looked like crap by the time I got rid of my GTA. It had developed a crack on one side that would ooze water for days after it rained or was washed.
Old May 19, 2005 | 02:51 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
yah something different..
have to use ur mind when the producer decides to just stop making parts for your car..
Old May 19, 2005 | 06:19 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
I still say you need a set of gold crosslaced rims...
Old May 19, 2005 | 08:51 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
LOL
mabye some phat 24" spinners
Old May 19, 2005 | 09:53 PM
Engine: SBC, LS-x
What did you paint those spongey ends with?
Another horrible aspect or that fackin' wing.
Old May 20, 2005 | 03:54 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
bondo and just spray paint automotive..
the car is going for paint next year we didnt wanna spend the money on getting a pro job on this spoiler we are probley not going to use it next year..
Old May 22, 2005 | 10:35 AM
~87Bird~2.8~'s Avatar
Car: 87 Firebird
Engine: Was 2.8, Now 350
Transmission: V6 T-5
Axle/Gears: 3.45 Open
bondo...that is the worst thing 2 use on that...i no u probly dont have a lot of expereance but that stuf dosent stick to anything but metal....in prob less then 6 months it will all crack and peal rite off...if thats the same kinda wing my buddy had on his camaro (all spungy, soft and cracks half and inch wide) the only thing that might! work (no promises) would be spot puddy...
its the stuff boddy shops use on rubber bumper covers...and to cover pin holes...it u can u schould scuff the paint (the only thnig it will stick 2) and put it on the same way as bondo...keep in mind it is ment for fine refinishing work...so its hard to snad...so put as lil on as possable
i dont no if it will work on theat stuff...but it willl be way better then bondo
Old May 22, 2005 | 10:56 AM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
well the spoiler right now isnt a concern
but ill keep that spot puddy thing in mind when we might redo it when we plan on getting the car redone but for now the bloody engine isnt doing so well
Old May 22, 2005 | 05:18 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Originally posted by davecamaro
... but for now the bloody engine isnt doing so well
It's the rims.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
