Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Passed Last E-test!!
Old Jun 14, 2005 | 11:56 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Passed my last e-test ever in the IROC this morning under hotrod status. I'm pretty pumped having to not deal with more future BS.
I put a stock MAF back on (from fully ported stocker with no screen) and ran McEwen Ethanol gasoline after having good results in my truck.
Here are the results, thought some of you might be interested.
Driving test - 1977 rpm
HC ppm; Reading 102 - Limit 242
CO%; Reading 0.57 - Limit 1.92
NO ppm; Reading 1182 - Limit 2520
Idle test - 1119 rpm
HC ppm; Reading 150 - Limit 300
CO%; Reading 1.43 - Limit 1.50
NO ppm; Reading N/A - Limit N/A
Here are the results form 2 years ago when it failed twice and figured to jack the idle up.
Driving test - 1993 rpm
HC ppm; Reading 109 - Limit 278
CO%; Reading 0.63 - Limit 2.20
NO ppm; Reading 1906 - Limit 2898
Idle test - 1215 rpm
HC ppm; Reading 242 - Limit 300
CO%; Reading 1.18 - Limit 1.50
Notice the limits have tightened even for the hotrod cars.
Old Jun 14, 2005 | 12:35 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Congrats Neil!! That's excellent. One more and I can join you.
Old Jun 14, 2005 | 05:29 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I'm glad to be rid of that crap too. What did you do to lower your NO readings so much?
Old Jun 15, 2005 | 09:18 AM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
My Camaro goes in Tommorow for its latest test, I'm nervous, gonna have to cheat as it has barely snuck by the last 2 tests.
Old Jun 16, 2005 | 01:22 AM
johnyIROC's Avatar
Congrats.... it was a great feeling when I passed the last one with my old car (Thanks 99% pure isopropyl!). There's no hope in hell of passing with the new car unless we do a cam swap.... if anyone has a hook up....
Old Jun 16, 2005 | 08:32 AM
Engine: LB9
Phew, squeaked by again The guy had to run my car in 2nd gear to get it to pass, high hydrocarbons. Safe for another 2 years......
Old Jun 16, 2005 | 11:34 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Didn't do anything to lower NOx..just the fuel and MAF was different from previous test.
The results are for the 95 LT1 with NO emissions equip at all.
Zedder, How did the 90 do for actual results?
Old Jun 16, 2005 | 11:53 AM
Engine: SBC, LS-x
Not even cats?
My 98 just barely fails witout cats. Tried several times. It's a PITA to put the cats on. I have to do it again now. Wonder how many exhaust manifold studs will break..........
I'm leaving them on this time. No more screwing around with that till I switch to long tubes.
Old Jun 16, 2005 | 12:02 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
No cat, has exhaust and a gas cap though.
Old Jun 16, 2005 | 04:51 PM
Engine: SBC, LS-x
LOL!
Tank vent and return line? Vapor canister? Still got the orb or that gone too? I know, it's vacuum powered HVAC.
I keep those things I mentioned. They take no HP.
Old Jun 17, 2005 | 07:42 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
The tank vent is still on the canister, but with no electrical connections to it...ie it never gets purged. The LT1 pcm doesn't have any such function so it's disconnected.
I didn't want to make it automatically purge with engine running so it didn't start dumoing in extra crap at low engine speeds.
Any thoughts on a better way to do this?
My fuel return line still exists per original.
What is Orb???
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
