Prom tuning in Niagara area?
Have you had any responses to this topic??? I am living in St. Catharines and am getting my feet wet in programming. However due to time restrains and too many other hobbies I have not had the time.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
What is the problem you are having??? I put a L98 from a 1989 in my Monte SS, so from the help of many here a 3rdgen I have a good amount of exp with this, and I am in Welland which is very local to you.
Car: 1994 s-10 with a TPI 5SPD
Transmission: Muncie 5 SPD
I have taken a 305 TPI out of my camaro and replaced it with a 350TPI. The block has a four bolt main and the heads are now World Sportsman II. I have all the specs on the heads. I went with these due to buget. The cam was swapped and I am running a TPIS ZZ-9 cam. The system is full hyd. roller. I have had the tranny redone with a shift-kit. All these mods are running on a stock ARAP bin. It runs alright, however the engine shifts out too early (@4500 rpm) and I know from shifting it manually there is a lot more there. I have adjusted the TV cable but it doesn't change the shift point. The engine also bogs under low rpm load. I am sure a good tune will help a lot. Oh I also have the Prominator installed so making any program modifications is a snap. I have datalogged a few times and notice that my BLMs are a little off. I am currently on vacation and will still be off next week. I am hoping to spend some time on a few of these problems before heading back to work.
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
tranny stuff - you can make WOT shift changes through the governor..The TV cable only affects part throttle shifts.This is assuming that the TV were adjusted by the book
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
A guy in Kitchener thats on this board once and awile called Trigger did my chip work, gained 10 RWHP and 25 RWTQ from it.
Hypertech chip - 262.1 rwhp 376.7 rwtq
Trigger chip - 271.3 rwhp 400.1 rwtq
To top it off it ran smoother and I got better gas milage, So I was happy with it.
