Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Stealthram
Old Nov 3, 2005 | 11:48 PM
rgauder's Avatar
Car: 1987 Trans Am
Stealthram
Yay, my holley stealthram just arrived today. Now I'm gonna throw it on the bridgeport and mill the ribs off the top.
Old Nov 4, 2005 | 04:10 PM
trigger GTA's Avatar
Car: 92 TA vert
i like the ribs on it personaly. but if you polish the top of it that might help it look better
Old Nov 4, 2005 | 04:42 PM
rgauder's Avatar
Car: 1987 Trans Am
Ya, I'm gonna polish the plenum then.
Old Nov 5, 2005 | 05:03 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
probably help cooling too
Old Nov 5, 2005 | 06:01 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
I think leaving the ribs on keeps it cooler. More surface area allows the heat to dissapate better. I would keep the ribs weld some more on and put a ram air hood on that allows cool air to pass over the stealth ram. Whatever you do the stealth ram will be cool.
Old Nov 5, 2005 | 08:50 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
How are you getting by the EGR issue ?
Old Nov 5, 2005 | 08:53 AM
rgauder's Avatar
Car: 1987 Trans Am
You may be right, but I don't think the plenum on the stealthram has much to do with dispersing heat. They've already been reported to run much cooler than the original tpi setup (GMHTP article). I'm also going to take a look and see if I can machine up an adapter for the throttle body that will angle it down a little bit, maybe helping with the slight hood clearance problem that the birds have. I'm also going to machine my own fuel rails from blanks, so if any of you other Ontario members need some, let me know.
Ryan
Old Nov 5, 2005 | 08:55 AM
rgauder's Avatar
Car: 1987 Trans Am
(cough) What egr issue?(cough). Actually I have an idea for incorporating an egr valve. Let me see how it works and then I'll post up the info.
Old Nov 5, 2005 | 10:48 AM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
just make sure its there if it doesn't work oh well but make it look like its hooked up.....if anything attach it and put a small ball bearing to block the way through the hose...
Old Nov 5, 2005 | 12:06 PM
rgauder's Avatar
Car: 1987 Trans Am
I've never had a problem with visual inspection around here, the East Indian gentlemen that run the emissions testing station near me don't have a clue as to what they're looking at!
Old Nov 6, 2005 | 12:21 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
It's the roadside DOT schit that you have to worry about.
Old Nov 6, 2005 | 06:33 AM
rgauder's Avatar
Car: 1987 Trans Am
That's the beauty of living in the city that has the busiest border crossing in North America. They're too busy pulling truckers over. I've never seen them pull a passenger car over around here, the odd pick-up truck with an improperly loaded bed, but that's it.
Old Nov 6, 2005 | 10:15 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
They have roadside inspections here sometimes and they mainly check cars for emission equipment. They like to set up in front of events where there's going to be a lot of modified cars showing up.
Old Nov 7, 2005 | 07:13 AM
curtis84ta's Avatar
not only at events but the MOT has a few spot check vehicles driving around....looks kinda like a police cruise (same graphics and such but with an orange stripe) and also its an exploder (explorer). i was lucky to get off with a warning but i played stupid (had new engine put in and "thought" it came with it) but still had to make the necessary changes or else they would have taken my plates the next time i was pulled over.
The Tank
Aug 30, 2015 06:16 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
Kingtal0n
Sep 29, 2002 11:15 PM
RGS1260
Aug 6, 2002 11:51 AM
