Sportsman IIs Stealthram
Old Aug 3, 2002 | 07:08 AM
RGS1260's Avatar
Stealthrammed 383
58MM 30IB inj Cam 503/510 224/230@ 50 112
700R4 3.73 Stall 2400? Street Tires 3600lB
How far should Igo with port work?
What should I tell the porting guy to do?
Any problem areas?
Mostly street and occasional strip use
Looking for 450-475 HP
Old Aug 6, 2002 | 10:52 AM
tpi_roc's Avatar
Sportsman II's are EXTREMELY rough cast, extreeeeeemely.
Problem areas would be the whole thing, they're good heads, but for that to be realized you've got to grind out all the cast, smooth the combustion chamber, and make sure to gasket match the sportsmans to the super ram, I'd suggest a Felpro 1205
Good luck
Old Aug 6, 2002 | 11:49 AM
RGS1260's Avatar
So dont open up the ports anymore that needed just make everything smooth and gasket match to 1205
Old Aug 6, 2002 | 11:51 AM
tpi_roc's Avatar
You shouldn't need to on the sprotsmans, they're 200cc intake runners, those are plenty good for a 383 if they're cleaned, with some bowl work. As far as the super ramn you can port the runners a tiny bit if you want, i wouldn't pay anybody to do it.
You should be fine, and plenty happy with the engine
seiplentz
Aug 19, 2019 06:02 PM
Night rider327
Sep 16, 2015 02:20 AM
The Tank
Aug 30, 2015 06:16 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
Dialed_In
Aug 20, 2015 01:45 PM
