Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
REPLACING T-TOPS
Old Jun 12, 2006 | 11:39 AM
koolbreeze92's Avatar
Car: 1992 Brilliant Red Metallic with T-
Engine: LB9 305 TPI
Transmission: MD8 4 Speed Automatic
Axle/Gears: 2.73....Paint peeler
REPLACING T-TOPS
My 92 bird has a problem. I have acrylic t_tops that look like they have shattered when u look out of them from the inside. (Obviously the original owner did not take care of them.)
I was wondering if I can swop them for glass roofs and what years of birds would match.
Im just tired of the prism look. Any info would be appreciated,thanks.
Old Jun 12, 2006 | 11:55 AM
The Phantom's Avatar
I do think that you can swap glass ones on, I'm pretty sure the only difference is in the latch. On yours I would think it has a pin style latch system?
I have a two sets one came off an 86 T/A and it fit my camaro. If you are around southern Ontario in the TO area there are lots of bone yards with F bodies in them. Check around.
Dave
Old Jun 13, 2006 | 03:17 PM
Engine: LB9 305 TPI
Thanks for the info Dave, just hope they have the key for the locks or can I switch them over?
Old Jun 13, 2006 | 03:38 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am sure everything can be swapped over, perfect time to reseal the t-tops anyway. You could also polish out the scratches in your old ones, do a search it has been covered before.
gta90
Sep 15, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
