HSR fuel rail help
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
HSR fuel rail help
I got the HSR all setup but have no fuel going pass the regulator to the rails, there is fuel to the regulator.
Im stuck, any help?
Im stuck, any help?
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Dunno if you know already but just in case..If you pull out the inside of the valve there should be tiny o-ring there..Its been a while since I worked on TPI though
