Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Prom for HSR
Old May 7, 2007 | 12:46 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Prom for HSR
To all who run HSR setups what prom are you using and where can I get one, I cannot get my engine to run smooth.
Even starting it cold takes a few cranks without the 9th injector.
My setup is GTA 350 auto without mods to engine.
Old May 7, 2007 | 05:19 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Prom for HSR
it should be custom
Are you using the stock camshaft?If you are then I think it would be difficult for it to run right or even if it does you will have less power than with the stock TPI..The stock cam's powerband starts to dip at 4500 while the HSR makes its power from 4500..
What other mods to the engine?
Old May 7, 2007 | 07:21 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Prom for HSR
Engine is a stock reman vin 8 for Camaro / Trans Am.
It might just be a good idea to go back to the old intake, maby modify the stock manifold / plenum and get some runners?
Probably better for my setup, although it still pulls nice with the HSR its still not running %100.
I plan on getting a cam sometime next year, not yet.
Havent broken in the engine yet, might have 12,000K on it so far.
Old May 8, 2007 | 11:18 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: Prom for HSR
Check out www.pcmforless.com and see what they can do..
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
